I captured a dv file in Premier 6.0. and created an avi file. I then tried to encode a MPEG2 file using the cinema Craft Lite Plug in for adobe. It created an unknown type of file that is not DVD compliant although I checked the dvd compliant box under the plug in. I tried to take the converted cinema craft file to Ulead Movie factory and I get a file format mismatch. Says it is unable to open. The file created from Cinema Craft encoder plays on windows media player, but will not open in Ulead or any other DVD authoring software.
Also I tried taking the dv avi file created in Adobe Premier 6.0 and dropped in the stand alone Cinema Craft Lite stand alone, and it said it could not find the video codec for dsvd.
Brian
Results 1 to 1 of 1
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 12:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 17:51 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 21:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 17:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 19:05
