Hi,
I want to create a DVD that consists solely of music videos. I created one using Nero Burning Rom in DVD-DATA mode, but the problem is that you have to manually scroll through each video and it gives you no option to burn the videos in a random order. On top of that, the DVD freezes about 10 videos in.
What I would like is to create a DVD full of music videos, but with some kind of menu where you can pick which one you want, and then allowing the option of continiously playing the rest once one has been selected (similar system to when you listen to any music album).
Do I need any type of software for this as i do not seem to be able to do it in Nero? I dont need any photo editing or audio editing plugins, fancy backgrounds or frames. I simply want a chapter(menu) system for playing a bunch of music videos for an in-car Pioneer DVD system.
Cheers.
You must author if you want a menu. You can try Nerovision that is included in nero ultra. I don't know if you can make a play all in nerovision though...I recommend tmpgenc dvd author 3 instead.
Any guides on creating continuous bluray menu music?
By aciras in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Oct 2011, 13:36 -
Play back Music Videos In My Car
By trevz87 in forum Portable VideoReplies: 6Last Post: 22nd Mar 2009, 19:58 -
Creating a dual boot system...best way?
By sdsumike619 in forum ComputerReplies: 11Last Post: 14th Dec 2008, 12:30 -
burning music to cd so it will play in car or standalone cd player
By deadman1972 in forum AudioReplies: 4Last Post: 8th Aug 2008, 06:43 -
Do you have a video entertainment system in your car?
By yoda313 in forum PollsReplies: 20Last Post: 25th Jun 2007, 21:43
