Well it has been a while since I have browsed these forums. I have run into a spot of trouble and I am not quite sure how to successfully demux the video stream and audio stream from a h264 ts file. I hope someone far smarter than me can help out.![]()
I have tried a variety of different methods that I have seen posted here and at doom9. I have used the program h264tsto and have gotten the elementary streams. I then run the raw video stream through yamb and get a mp4 file. However, when I play the mp4 in media player classic with haali media splitter, the opening studio logo and opening credits become a blocky mess. The strange part is that the rest of the film seems unaffected and works as it should from what I can tell.
I have used mencoder to demux and get the same result as above. I have also used avisynth with the directshowsource filter and get the blocky opening but the rest works fine. I suppose my question is why would the video be affected in only that tiny beginning segment of the movie and how can I fix it. The source ts file doesn't exhibit any problems at all.
Hopefully I was specific enough in describing the problem. I will link a picture of what I am talking about. Any help would be great. Thank you.![]()
Here is the screenshot. http://img162.imageshack.us/img162/1993/videolf8.jpg
I can try to post different images or something if need be.
Just thought I would update the thread, since nobody has said anything, and report that I found a more complicated method to get the file without any blockiness in the beginning. Basically I just run the directshowsource script through virtualdubmod and output using huffy codec in avi container. Then just use the avi as the source in a new script and load that into megui for mp4 conversion. It takes a ton of space and is a convoluted way to get the file perfect but it appears to work well so I am content. Anyway hope that helps someone if they come across the same problem in the future.
Converting MKV (H264/DTS) + Speedup to 25fps for PS3 Playback > Help Needed
By flexx in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 06:28 -
Any way to rip/demux .ts h264 subtitles?
By rocka in forum DVB / IPTVReplies: 5Last Post: 2nd Jun 2010, 15:08 -
H264 to MP4 for PS3 or XBOX360
By DVDONE in forum Video ConversionReplies: 4Last Post: 27th Mar 2010, 15:07 -
Demux DVB-S HD H264/AAC HE
By erbipjr in forum DVB / IPTVReplies: 3Last Post: 3rd Sep 2009, 14:48 -
Large MKV (h264) File to PS3 MP4 without re-encoding
By icue in forum MacReplies: 0Last Post: 29th Sep 2008, 18:14
