I am having a problem and maybe someone can help me. When I try to play xvid avi's in Windows Media Player and also the bsplayer, they are green and it is impossible to view the file. When I burn them as a Video DVD thru Nero, the same thing happens. Here is the clincher tho. My XBOX is connected to my home network, and the videos play perfectly fine on that. I checked Gspot and everything is installed. Any ideas?
This is really frustrating.
Thanks!
Only Xvids? Then it may be a codec issue. Try playing one in VLC Media Player. It uses it's own codecs. If it works, then reinstall your Xvid codec. If not, maybe a Active X problem.
They play beautifully in the VLC Player, but I reinstalled the xvid codec and I still get the same problem in windows media player. This would be the end of my problem, but it is still doing the green stuff and not playing correctly when I burn it as a Nero Video DVD
We're getting there!!! -
You should also make sure you're using the latest version of the XVid codec, too. Download the latest version and install it, see if that helps.
If cameras add ten pounds, why would people want to eat them? -
I've seen this before - and having just reinstalled my operating system, I'm experiencing it again. I am pretty certain that I recall this being one of two things (but I'm struggling to remember which);
1) Are you using an ATI card? If so, there is a parameter you may need to disable that relates to video playback. I can't yet remember what this parameter is (because I can't find it), but I do recall that it wasn't something universal, such as slowing down the overall hardware acceleration - it definately related only to video playback. It may be that I'll need to reinstall the Catalyst Control Centre in order to find this option ...
2) There is a specific codec that is reported to be absent in many installations - I think it was either an WMV or WM9 codec (related to Windows Media player, perhaps). I actually use Media Player Classic in most circumstances, as opposed to the Microsoft offering, for the record. I tried downloading a codec from microsoft a few days ago, but it had no effect - so I'll try to dig up the one I may have used before, as I almost certainly would have saved it to disc.
Apologies for being so vague - but I thought that this might help point you in the right direction. I'll try to report back if/when I resolve my issue once again.
Hobbes
P.S. When I first saw this, I was using an ATI 9700 Pro card. I fixed the issue, then later used an ATI X1600 Pro card - but the problem only reared it's head once I reinstalled the operating system - so both cards are undoubtedly capable of running just fine. -
Also have this - with some encoders.
Solution? To frameserve to the encoder with AviSynth.
/Mats -
Okay - found it. There's an old Windows Media 7 related codec that's required - I've just installed it, and it worked just fine.
You can download it from my server >here!<
I grabbed this some time ago - possibly from the Microsoft site - but I have no doubt that there's nothing you need worry about regarding the file. The file's about 1.35mb, so it should be a painless download, and it hasn't conflicted with any other codecs or codec packs, so far (I'm currently using the K-Lite offering).
Hope this works for you!
Hobbes
Will the created BDMV burn correctly and start at the beginning?
By pepegot1 in forum Blu-ray RippingReplies: 2Last Post: 5th May 2011, 08:37 -
Unable to burn a DVD (Mac)
By kayar in forum Authoring (DVD)Replies: 4Last Post: 9th Jan 2010, 14:36 -
.mpg won't open/burn correctly-help!
By keltoid in forum Video ConversionReplies: 6Last Post: 14th Dec 2009, 12:11 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
how to correctly burn iso that FAVC makes using ImgBurn
By brentonboy in forum Newbie / General discussionsReplies: 8Last Post: 19th Dec 2007, 16:54
