I captured a DV video from my miniDV camera with Quicktime on my MacBook. But it seems as if Quicktime messed it up and created some .mov out of it. When I try to convert it with ffmpegX (0.0.9x r2) the audio stream will not be encoded no matter what format I convert it to. VLC isn't even playing the audio of the .mov Quicktime built.
I am new to DV and Mac. Is there a free (or at least low priced) program to capture DV on a Mac?
thuriel
Results 1 to 12 of 12
I did already try iMovie. I want to A/D convert an old VHS tape. So the plan is to directly capture the DV stream wich the camera puts out. The problem with iMovie is, that when I click 'Import' to start the capturing, it immediantely starts playing the miniDV tape inside the camera instead of capturing the DV signal. So that disqualified iMovie
I did not see any option for capturing in iDVD. How can I capture with iDVD? -
Look for a preference option to turn off DV device control.Originally Posted by thuriel
There is no such option in my version of iMovie (6.0.3 (267.2)). I think that wouldn't solve the problem anyway. iMovie only shows a blue screen instead of the video footage from the analogue source. Is there no freeware that can handle DV capture ...or a tool of MacOS I didn't discover yet?
You must remove the tape for this to work! I also have to configure the Sony TRV320 camcorder settings and toggle the camcorder's DISPLAY button to the right position.
But unfortunately some analog to DV passthrough converters don't work in iMovie HD 6.0.2 like they do in iMovie 4.0.1:
I used to be able to convert analog to DV in passthrough mode with iMovie 4.0.1 and my Sony TRV320. But iMovie HD 5-6 broke it for my camcorder model. It works for other models.
This is the main reason I still have iMovie 4.0.1 in my system: I digitize with it and post-process the project with iMovie HD 6.0.3.
Another good option would be to use BTV Pro instead of iMovie.
For more info see:
http://www.sjoki.uta.fi/~shmhav/iMovie_HD_6_bugs.html#analog_DV -
When I try to start capturing with Vidi, I get this error message:Originally Posted by Frobozz
"Recording could not start
Recording could not start due to a problem.
(OK)"
Do you know this message? Do I have to do something bevor capturing?
I tried it with removing the tape. iMovie then said something like "No tape inserted". So it seems that my DV cam (Canon MV850i) is affected by the iMovie bug you're writing about.Originally Posted by havema-1
Where can I get iMovie 4.0.1 from?Originally Posted by havema-1
I installed BTV Pro but the .mov it produces has the same problems like the one built by Quicktime: It's soundtrack can't be played by VLC and it cannot be transcoded bei ffmpegX.Originally Posted by havema-1 -
I just changed the output directory from my home folder to Desktop. Suddenly it worked. The .dv file I get has sound in VLC and I can work with it in ffmpegX.Originally Posted by thuriel
Thank you very much!
PS: The only thing I don't like, is that Vidi starts a server wich doesn't quit automatically when I quit the client ...and that it automatically adds the server to the login items. But at least I finally get a clean .dv file
Yes, I wish there was an option to prevent the login item being added with Vidi. Another option is to go to Apple's Developer site and download the latest FirewireSDK package. It includes a DV capturing application. It, too, is free.
eBay etc...
I always capture as .dv (not .mov) because handling plain DV streams is more predictable (if they are correctly flagged as 4:3 or 16:9) and I have had no trouble post-processing .dv. Haven't much used VLC for .dv, though.
BTV Pro can capture as .dv, too. -
iMovie 4.01 can also be re-installed from either :
1. an iLife '04 disc
2. System restore discs for iBook G4s, PPC G4 towers,
or eMacs where the main system disc states it is
OS X 10.3.5 or later."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
VHS Capture my Mac?
By The Sumerian in forum MacReplies: 1Last Post: 25th Jan 2010, 12:17 -
Best capture application Mac
By wahsac in forum MacReplies: 13Last Post: 4th Oct 2009, 16:50 -
HELP! Capture with MAC but I need to edit with a PC!
By blainedepue in forum Video ConversionReplies: 2Last Post: 27th May 2009, 11:39 -
Capture on Mac - read DV on PC?
By maveni in forum Capturing and VCRReplies: 18Last Post: 5th May 2009, 10:01 -
Capture problems with Mac
By kevs in forum MacReplies: 4Last Post: 3rd Jun 2007, 20:58
