Hi,
I currently use Premiere Pro 2.0 for my firewire/DV capture for my business.
A client wants me to do work using 2 camera mix and uses SVHS cameras/VHS-C.
I want to be able to do multicam in Premiere Pro but how would I go about capturing the SVHS via USB 2.0?? I was looking at a 'dazzle' capture card but only captures via MPEG2 would that work on adobe?? I only have experience with .AVI files.
Thanks for your help.
If you normally work in DV (as I do), I would say your best bet would be to use you camcorder as a passthrough device. Then you will be transferring over Firewire as DV irrespective of what format or media the source is.
Personally, I wouldn't go for any of the USB capture devices unless you get one of the Canopus ADVC units that do the same job as a camcorder with passthrough. -
One problem with that,
Client does many tapings a week and is only able to send me the tapes to edit, the module you suggested is quite pricey..quality isn't an issue so anything on the 'low-end' would be fine.
Thanks -
If he only sends you the tapes, how are you supposed to play them back? If, as I said, you have a digital camcorder capable of passthrough, use that instead of a Canopus, it'll do the same job using something you (hopefully) already have.
If you don't have a DV camcorder with pass through you can buy a used one on Craig's list quite cheap but do your research on which models have that feature.
If you are using Premiere Pro 2, an ADVC type DV transcoder device (also ADS Pyro, DAC-100/200, etc.) will also allow you to output the Premiere timeline to a video monitor so you can see what you are doing. This is even more important for VHS sources. A camcorder can do this as well but requires a different brightness setting on the TV.
Windows Movie Maker capture import to Premiere Pro
By burrenyoga in forum Capturing and VCRReplies: 5Last Post: 24th Aug 2010, 10:36 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
AVCHD or HDV Capture in Premiere Pro CS4?
By AjSVB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 2nd May 2010, 14:08 -
Adobe Premiere Pro Not Recognizing Capture Card
By ercdill in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2008, 15:59 -
HD Capture questions w/ Premiere pro
By miamibluemoon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 27th Feb 2008, 02:38
