I'm a newbie who's tried hard to find an answer on the forum, in the how-to's, etc. but haven't gotten anywhere.
I recently downloaded wmv video files (with sound) from a copyright-free gov't site.
The files include audio.
When I use ffmpegx to convert to mov, mpeg, avi, whatever (I'm on Mac G5), the audio looks great but the audio gets lost.
What am I doing wrong?
I've hunted and pecked in the ffmpegx interface to figure out what to do.
Does anyone have a suggestion?
Thanks.
Please provide some details on your source file, as indicated in the Summary tab.
Hi case,Originally Posted by Case
here's a screen shot of the source file summary.
The source file summary reads:
video: wmv1, yuv4209, 640X280
audio: wmav2, 44100Hz, stereo, 128 kb/s
I have noticed that the original file's audio only comes out of one speaker, if that makes a difference.
What would you suggest?
Thanks,
Adam
I found a short WMV file with wmv1 video and wmav2 audio, and got these results:
• Convert to MOV mpeg-4 (ffmpeg), Invert mapping: MOV has video+audio.
• Convert to MPEG (ffmpeg), Invert mapping: MPG has video+audio.
• Convert to MPEG (mpeg2enc), Decode with mplayer: only MPV (video) created.
• Convert to MPEG (mpeg2enc), Decode with Quicktime: MPG has video+audio.
• Convert to MPEG (mpeg2enc), Decode with ffmpeg, Invert mapping: only M1V (video) created.
• Convert to AVI XviD (mencoder): AVI has video only.
• Convert to AVI XviD (ffmpeg), Invert mapping: AVI has video+audio.
• Convert to AVI DivX (mencoder): AVI has video only.
• Convert to AVI DivX (ffmpeg), Invert mapping: AVI has video+audio.
So it seems you would be best off using the ffmpeg engine.
The ffmpeg engine wants video to be stream #0.0 and audio to be stream #0.1. Some video files, like many (all?) WMVs, have these inverted. That will cause the conversion to fail. To fix that, one can set the Invert mapping checkbox in the Audio tab.
Converting .dv and .mov Mac file to MPEG-2 No Audio
By RL in forum ffmpegX general discussionReplies: 3Last Post: 30th Jan 2011, 06:47 -
Should converting a mov file to wmv be so small?
By abrand88 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2010, 14:47 -
Converting MOV PhotoJpeg to h264 without quality loss.
By JRM in forum Video ConversionReplies: 3Last Post: 2nd Mar 2009, 23:46 -
Banding when converting MOV to WMV
By whoisquilty in forum MacReplies: 2Last Post: 22nd Jul 2008, 11:35 -
Converting layered WMV files to MOV
By whoisquilty in forum MacReplies: 3Last Post: 19th May 2007, 14:18
