    May 2007
    hi
    does anyone have expericance with theLG DAT-200
    mines randomly freezing, loosing sound, pictures, failure to read disc etc. it all seems to be the same problem, when this happens the only button that works on the remote is the power button.
    ide try firmeware but havent been able to find any around or anything on this system at all.
    this is why i want a standalone 5.1 player.
    cheers
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Is this occuring with commercial discs or copies? If they are commercial discs, it could be dirty discs or a dirty player. If they are copies/burned discs, then it is most likely a media issue.
    Google is your Friend
    May 2007
    hmmm with both, tho all the error i gave seem to be connected to the same one big problem i think, i can go weeks or without a problem then it can keep happening sumtimes i have to keep turn it on and off until it doesnt free because i dont think it has a problem reading the disc i think the hole system is freezing sumhow, when a dvd does fail to read i can switch to tv mode but the audio will be gone.
    weird!!!!
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    In that case, sounds like hardware failure. It would most likely be cheaper to replace it and have it fixed. But if you know a shop that will check it out free/cheap, it would be worth a try.
    May 2007
    well this is where i want to find a standalone 5.1 players but i cant find one, they all have digital out . surely loads of ppl wants standalone players, uk remember
    and u cant find a dat200 anywhere dammit
    does this have 5.1 connectors Yamada 5520
    i dunno what to buy if i get a full home cinema set only wanna spend like 100-150 or so
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The 5.1 players were more common because the AVR's with digital inputs were expensive. Now that even the cheap AVR's have digital inputs, often multiple including coaxial and optical, there is no need/reason to increase the cost of the dvd player to provide outputs a huge majority of users won't use.
    Maybe it's time to upgrade your AVR?
    May 2007
    i just dont wanna waste the speaker that r already setup around my room
  8. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You don't have to replace the speakers.
    Typically, you have the 6 sets of RCA cables connected from the DVD player to the receiver/amplifier. And then the 6 sets of speakers wires from the receiver/amplifier to the speakers. This is usually done because the receiver/amplifier doesn't support 5.1 decdoding, so you allow the DVD player to do the decoding.
    With a newer AVR, it performs the decoding on its own. So you connect a single digital (coaxial or optical) cable from the DVD player to the AVR. Then the six sets of speaker wires still connnect directly to the AVR and your speakers.
