Hi Folks,
I have problems with my DVD 3800.
When i burned a DVD almoste every DVD, is suttering or freezing.
Wich software do you use and wich media ?
Now i have Philips 4x with a NEC 3120 burner.
Greetings
Xsienix
Results 1 to 11 of 11
For a $3000.00 device I just dont understand why Denon still refuses to ad SACD support along with their DVD-A capability.
Anyway, I would use Taiyo Yuden G02 8X -R media. Make sure to use "- (dash)" as there is no explicit support for DVD+R/RW. I guess you already know that though. Also "Mode 1 " seems superior to mode 2.
Nice unit you got there.
Regards,
NL -
Thanks for the advise,
I Have burned a Verbatim DVD-R using Nero. I still get the freezing, probs.
Tomorrow i will burn again a Verbatim using the program gunslinger is teling me.
@nitelight...mode 1, 2 ? iam searchin, and searchin, but what does that mean, and where must i set this in my burnprogramm ?
And, yes its a nice DVD player, but this problem, takes al the fun out of it.
First i will try another burnprogramm
Whats the difference anyway ??
Xsie -
this is a known problem with this denon ..... there is no good solution other than replacing it with another player for burned disks ...
the 10 grand krell also has the same issue so dont feel bad"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Holy cow !Originally Posted by BJ_M
There must be a solution that the player will accept burned DVD.
I've red some stuff about a faulty laser-pickup with some specific serials of these 3800 players.
Meanwhile ths whole thing driving me nuts.
Wish there was anyone here on this forum who can tell me the right burn/band DVD solution.
Xsie -
I guess that's the only way to do it..
I informed and a laser-repair cost me a 120 euro.
And with a risk that iam not sure that the player can read burned DVD properly.
So ,,a bit off topic
Any suggestions wich DVD player "eats" everything ??
Many thanks for helping me !!
Xsie -
I have a denon DVD-3800 also. I use Maxell dvd-r 16X media and have no problems at all. I use Nero 7.5.9.0 for burning dvd's. My Denon unit was manufactured in September 2002. I have also had success with benq 4X media as well as Memorex DVD+R DL 2.4X. The unit is not even supposed to accept and +R media but does some and not others. I wish you success as this unit is a very fine product. I use it primarily for an audio player and most often for listening to dvd-audio and 5.1 dts audio disks. The sound is spectacular. I have several MP3 dvd's burned on Maxell media and even MP3's sound fantastic played through this player. I almost forgot....WinXp SP2....LG 16X burner with 2.4 dual layer capability. Good luck.
Dear Fongolio,
Ok, i give it a shot, and buy some Maxell DVD-r right away...
Do you know what mediacode the Maxell's are (Ritek1 ?), and witch speed do you burn ?
I will let you now the results.
Many thanks for this replay !!
Fongolio is that a bird or something
Greets
Xsie -
HE MAN !!!Originally Posted by xsienix
It's working..
I updated my Nero, and get some Maxelles and the player did play them...!!
Later i burned philips, and verbatim, and they worked als flawless.
An update for Nero was the thing !
Greets
Can you help me to decide wich software to buy from the following?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2011, 08:05 -
DENON DVD-1500 does not play any discs...
By jOlDMaN in forum DVD & Blu-ray PlayersReplies: 5Last Post: 7th Jan 2011, 05:18 -
MKV to IPOD conversion with the audio track that I choose. Wich software?
By fgtan in forum Video ConversionReplies: 5Last Post: 14th May 2010, 23:09 -
Denon DVD-1940CI multi hack please :)
By talla in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Jul 2009, 12:32 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 12:39
