I'm having a problem using vob2mpg.
I ripped a DVD using DVDDecrypter. This worked flawlessly creating the 7.5GB collection of VOB files.
I pointed vob2mpg at the VIDEO_TS folder where the ripped vobs were stored, and gave the program a good destination folder. The destination is a vacant 30GB IDE hard drive.
When I hit "Proceed" the program immediately hits 100% and gives the message:
Finished prossessing 1 vobsets
Duration 00:00:01
I have tried this program with no fewer than 10 DVD titles I have, and get the same message. A zero byte MPG file is created in the destination folder.
I've even tried to use VOB files from DVDs that I have created myself, so there is no connection with encryption. Same result.
I've tried at least seven different computers. CPUs range from AMD Thunderbird 1Ghz, Intel celeron 1.4Ghz, 2.0Ghz, 2.2Ghz, and Pentium 4 2.6Ghz, 2.8Ghz and 3.0Ghz. The minimum memory I have used is 512MB. The max memory is 1.0GB. All memory is either PC133 SDRAM or PC2700 DDR-SDRAM.
I've tried using the program under windows 2000+SP4 and Windows XP+SP2. Both OS have the .NET 2.0 installed.
Since there is nothing to configure with this program I'm am at a loss as to what I can check next. Has anybody else run into this problem, and how to fix?
My attempts on the P4 2.6Ghz and 3.0GHz were fresh installs of Windows 2000 and WIndows XP respectively. Only the service packs, and .NET 2.0 were installed.
I am baffled.
Here is the full text of the log that was created with my last iteration:
Code:******************************************************************** ************************ SYSTEM INFORMATION ************************ ******************************************************************** ***************************** VOB2MPG ***************************** Name: VOB2MPG Title: Version: 2.3.0.0 Executable: C:\_document\temp.downloads\_bin\VOB2MPG.v2.3\VOB2MPG.exe Executable size: 640 KB Executable size in bytes: 655360 Executable CreationTime: 5/17/2006 1:56:22 PM Executable LastWriteTime: 3/14/2006 10:49:26 PM Executable LastAccessTime: 5/16/2007 2:43:59 PM ****************************** Drives ******************************* DeviceID: C: FileSystem: NTFS Size: 37.2 GB FreeSpace: 16.1 GB DeviceID: D: FileSystem: FAT32 Size: 11.2 GB FreeSpace: 3.92 GB ******************************************************************** ********************* END OF SYSTEM INFORMATION ******************** ******************************************************************** ********************** Input Folder ******************* 10:38:24: Volume in drive D is IBM_11GIG 10:38:24: Volume Serial Number is B424-3967 10:38:24: Directory of D:\hp.stone\VIDEO_TS 10:38:24: 05/16/2007 09:21 AM <DIR> . 10:38:24: 05/16/2007 09:21 AM <DIR> .. 10:38:24: 05/05/2007 01:31 PM 10,240 VIDEO_TS.BUP 10:38:24: 05/05/2007 01:31 PM 10,240 VIDEO_TS.IFO 10:38:24: 05/05/2007 01:59 PM 104,448 VTS_01_0.BUP 10:38:24: 05/05/2007 01:31 PM 104,448 VTS_01_0.IFO 10:38:24: 05/05/2007 01:31 PM 81,911,808 VTS_01_0.VOB 10:38:24: 05/05/2007 01:36 PM 1,073,739,776 VTS_01_1.VOB 10:38:24: 05/05/2007 01:40 PM 1,073,739,776 VTS_01_2.VOB 10:38:24: 05/05/2007 01:43 PM 1,073,739,776 VTS_01_3.VOB 10:38:24: 05/05/2007 01:44 PM 342,503,424 VTS_01_4.VOB 10:38:24: 05/05/2007 01:47 PM 1,073,739,776 VTS_01_5.VOB 10:38:24: 05/05/2007 01:51 PM 1,073,739,776 VTS_01_6.VOB 10:38:24: 05/05/2007 01:55 PM 1,073,739,776 VTS_01_7.VOB 10:38:24: 05/05/2007 01:59 PM 760,854,528 VTS_01_8.VOB 10:38:24: 13 File(s) 7,627,937,792 bytes 10:38:24: 2 Dir(s) 4,217,110,528 bytes free 10:38:24: D:\hp.stone\VIDEO_TS> ********************** AV Details ******************* file=D:\hp.stone\VIDEO_TS\VTS_01_1.VOB FormatName=mpeg Num_Frames=40225 DurationInSecs=1342 Duration=00:22:22.1 VideoCodec=mpeg2video Width=720 Height=480 Standard=NTSC BitRate=6399 AudioStreamCount=2 Audio1StreamID=[0x80] Audio1SampleRate=48000 Audio1Codec=ac3 Audio1BitRate=448 Audio1Channels=6 Audio2StreamID=[0x81] Audio2SampleRate=0 Audio2Codec=ac3 Audio2BitRate=0 Audio2Channels=0 ************************ END ************************ 10:38:24: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard 10:38:24: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads 10:38:24: libavutil version: 49.0.0 10:38:24: libavcodec version: 51.4.0 10:38:24: libavformat version: 50.2.1 10:38:24: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special) 10:38:24: Input #0, mpeg, from 'multi:D:\hp.stone\VIDEO_TS\VTS_01_1.VOB*D:\hp.stone\VIDEO_TS\VTS_01_2.VOB*D:\hp.stone\VIDEO_TS\VTS_01_3.VOB*D:\hp.stone\VIDEO_TS\VTS_01_4.VOB*D:\hp.stone\VIDEO_TS\VTS_01_5.VOB*D:\hp.stone\VIDEO_TS\VTS_01_6.VOB*D:\hp.stone\VIDEO_TS\VTS_01_7.VOB*D:\hp.stone\VIDEO_TS\VTS_01_8.VOB*': 10:38:24: Duration: 00:02:23.6, start: 0.045500, bitrate: 420348 kb/s 10:38:24: Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 7500 kb/s 10:38:24: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s 10:38:24: Stream #0.2[0x84]: Audio: ac3 10:38:24: Assuming NTSC for target. 10:38:24: Output #0, dvd, to 'C:\_document\stone\VTS_01.mpg': 10:38:24: Stream #0.0, 29.97 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 7500 kb/s 10:38:24: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s 10:38:24: Stream #0.2: Audio: ac3 10:38:24: Stream mapping: 10:38:24: Stream #0.0 -> #0.0 10:38:24: Stream #0.1 -> #0.1 10:38:24: Stream #0.2 -> #0.2 10:38:24: [dvd @ 0069DF34]sample rate not set 10:38:24: Could not write header for output file #0 (incorrect codec parameters ?) ********************** Output Folder ******************* 10:38:24: Volume in drive C has no label. 10:38:24: Volume Serial Number is 8439-63AE 10:38:24: Directory of C:\_document\stone 10:38:24: 05/16/2007 10:38 AM <DIR> . 10:38:24: 05/16/2007 10:38 AM <DIR> .. 10:38:24: 05/16/2007 10:38 AM 0 VTS_01.mpg 10:38:24: 1 File(s) 0 bytes 10:38:24: 2 Dir(s) 17,304,293,376 bytes free 10:38:24: C:\_document\stone>
It appears the following is the reason the files ar e not getting created
I'm a bit fuzzy on how this can be resolved, since the ffmpeg.exe that is being used came with the program binary...Code:10:38:24: Could not write header for output file #0 (incorrect codec parameters ?)
Try loading the first VOB into the batch function of MpegStreamClip 1.1 for Windows
BTW - Don't include VTS_01_0.VOB - that's the (usually) silent intro and can mess up your A/V sync.
vob2mpg
By peebee44 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Dec 2011, 15:02 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 00:53 -
vob2mpg, 1st try, two different machines, neither work
By Hoooooooar in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th Jan 2010, 23:26 -
Where to get vob2mpg v2
By freq in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Nov 2009, 11:47 -
VOB2MPG 0 Vob Sets Problem - wont work
By meno in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Oct 2007, 21:36
