I have avi file captured from TV as DV type 2. I loaded file to VirtualDubMod through avisynth and cropped unwanted portions of video. Then exported avi to a new formats for testing (lagarith and mjpeg). The resulting new avi file, loaded to AutoGK.
Here is interesting part, I did some test with original DV type 2 file and AutoGK, after analyzing source file, AutoGK states that "Source is considered to be interlaced." When I load new file (lagarith and mjpeg) AutoGK says that the "Source is considered to be hybrid (mostly FILM)."
Of course at the end the final converterted file (divx) looks OK, but when there is a fast motion the image becomes a bit distorted. The original file (DV type 2 ) converted to divx looks and plays perfect
Hi-
You're a little unclear exactly what you did to it, but there's at least a fair chance that by cropping it (and resizing it?) you messed it up beyond AutoGK's ability to examine and fix it.
Are you saying you made a basic AviSynth script and actually cropped it in VDub? Why? How much did you crop, and did you do anything else to it? -
I did not want to do too much processing in VirtualDubMod, therefore I loaded file to VirtualDubMod through Avisynth option, under filters selected null processing and cropped file (60 from bottom and top). Because file can be exported only in full processing mode, I had to select video codec, unfortunately Canopus DV codec will not work in VirtualDubMod, so I decided to use other codecs lagarith and mjpeg. Then saved file as a new avi.
I checked file information for original file in VirtualDub (color YUY2), the new file color is RGB, however in settings for lagarith I selected the same color as original YUY2. Still, AutoGK spit out the same message that source file is hybrid.
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 19:48 -
UnViewable type2 AVI
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 12th Sep 2007, 22:35 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 05:30
