how can i encode mpeg2_files to SVCD using CCE-SP 2.64 encoder?,
or it working only with AVI format?
SKeeper
It is possible to use CCE to encode SVCD from DVDs or other MPEG2 sources, however it is a much more complicated process that using TMPGEnc. I suggest reading the guides on Doom9.net or try using the program DVD2SVCD. It take care of all the complex frameserving issues and leaves you with to ready to burn images. Hope this helps.
cce sp 2.64 accept .avi, .mov and DV sources, not MPEG.
But you can frameserve a MPEG source with VFAPI to cce 2.64.
DVD2SVCD does not work with cce sp 2.6x.
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 21:50 -
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 13:12
