I am having a couple problems video-wise on my CPU.
1. I have a DVD-ROM drive, but a while ago, my computer stopped installing some of the drivers and software off of my restore CDs. What software do I need to begin playing DVD's again?
2. Riva FLV player is giving me lag on the audio. Is this normal?
1. Can you see the files on the dvd if you use windows explorer ? Or can't it read dvds at all?
2. Try another flv player like VLC Media Player. -
it doesn't even recognize DVDs period. I can't even see the files.
Before replacing the drive , clean it , failing that , check the cable has not come loose or failing , it happens .
If you have replaced the cable attached to the drive and mainboard , try swapping the drives power connectors with any freely available units inside the case .
If it works from then on , psu might have an issue you are unaware of , it happens .
If it still has issues , then a new unit would be required . -
I would also verify that it is having issues with commercial discs and discs that you burned. If it can read commercial discs and not your burned discs, then it is most likely the result of cheap/failing media.
Google is your Friend
Which CPU specs to go for?
By A Traveller in forum ComputerReplies: 42Last Post: 13th Aug 2011, 12:26 -
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
Upgrading M/B & CPU, no other existing hardware, likely problems ???
By blinky88 in forum ComputerReplies: 5Last Post: 15th Aug 2008, 15:02 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
