Ok this is my player( 3 links with info about it)
https://www.videohelp.com/dvdplayers?DVDname=sony+dvp+s336&Submit=Search&Search=Search&...y=Name&hits=50
and here
http://www.virtualmags.com.au/Sofa/reviews/dvdplayers/Sony/sony_dvps336.htm
and here
http://www.michaeldvd.com.au/HardwareReviews/Sony336/Sony336.asp
I have a DVd that will play on my PC and my cheapy £20 player from Asda(when selecting DTS 5.1 Audio)
However my sony will not play any audio.
I think its due to the DTS audio as stated it plays on cheap player only when DTS 5.1 is selected so im presuming this if where the problem lies.
Im really not sure what im rading through the specs as i think my Sony has DTS(i have tied enabling it but still no sound)
Can someone help me out please?
Many Thanks
The last article you listed says:
DTS digital output is supported by this DVD player, but as mentioned previously, you need to enable this in the player's set-up menu, as it is disabled by default.
Have you not gone through the set-up menu? This article also says:
Oddly, the default setting for DTS output from this DVD player is OFF, which may cause some consternation for some users until they find this option in the setup menu.
Go into your set-up menu and you should be able to fix this. -
Yep after reading through that last link i set DTS to on but still no joy.
And you have the digital (optical or coaxial) output connected to an AVR that supports DTS?
Google is your Friend -
Aha, no i havent done that or have a clue what that is or how to go about doing itOriginally Posted by Krispy Kritter
Outa interest how is that my cheapy player, played on portable tv can play it as that is only connected via scart socket? -
Most likely, the other player isn't playing the DTS track, it's playing the stereo track. Especially not across scart to the TV. To actually be able to hear/use the DTS track, you need a DTS capable AVR (audio/video receiver). You then connect the digital output (optical or coaxial) from the dvd player to the AVR. Of course the AVR is then connected to your 5.1 or higher speakers. If you don't have a DTS capable AVR and surround sound speakers, then you don't need to worry about DTS (or DD 5.1).
Sony dvd - DVP-NS728HP/B USB video problem
By dreamcast in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Oct 2012, 22:56 -
Sony DVP-SR200P problem
By Andy312 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Feb 2012, 19:53 -
By dreamcast in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 15:26 -
Sony DVP S360 DVD player - No DISC problem
By weenie02000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Aug 2009, 09:43 -
Problem with Sony DVP-NS355 : Gets stuck at welcome message!?!
By Nilhanth in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Jun 2007, 13:44
