  1. I used SUPER to convert a rmvb file to mpeg II. I then use the mpeg II file as the input to TMPGEncDVD Author 1.6 to create DVD. I selected video bitrate of 1152 on Super and the conversion was completed with no problem. However when I use the output mpeg II file on TMD Author, it complained that the Video bitrate 104857 kbps is too high for a standard DVD.
    I thought 1152 I selected is well below the 9800 limit of DVD. Any idea what's wrong ?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    just ignore error
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    @ 1152 kbps, I think you'd be better off with mpg1, basically VCD specs mpg.
    /Mats
  4. Banned
    Freedonia
    At this low of a bitrate, you should also not use full height DVD resolution but use a VCD type resolution of either 352x240 (NTSC) or 352x288 (PAL).
    Most likely in your case Super did not correctly write the output header information when it converted your file. The commercial Teco Bitrate Viewer at http://www.tecoltd.com could be used to change the header, but I'm not sure that it's worth buying it just to do this on one file. I also don't know if TMPGenc DVD Author will let you ignore the warning or not.
  5. Thanks for the qick response. The original rmvb file is VCD or less quality anyway so I am not sure increasing the bitrate will make it any better. I have to put as much as I can onto a DVD without much reduction in quality from original. So I am using 352X240 and 1152 bitrate which I think is VCD quality. lI am not sure if TMD Auther will take mpeg1 as input for building DVD but I'll try.
    I understand that I can ignore the error. But I just worry that if the file is actually having a bitrate of 104857 (I doubt very much) and it will not play on a standard player. I want to be sure before I create the DVD. I am sending the DVD to a friend oversea where basic DVD player is already considered luxury item. Is there any software that can examine the output file to see what the actual bitrate is ? I saw in another entry that the bitrate detected by TMD Author may just be some data in the header and not the actual bitrate.
  6. Banned
    Freedonia
    Yes, the Teco Bitrate Viewer I just mentioned, but do note that the free version is extremely limited in what it can do and it can't modify MPEG stream headers like the commercial one can. The Restream program (listed in the Tools section to the left) may be able to fix your header problem and it's freeware. You'll have to take a look to see if it can do this. I don't know.
    I don't have TMPGenc DVD Author, but I think others have reported that it will accept MPEG-1 video files for DVD. I have been able to author MPEG-1 to DVD using Scenarist, but it demanded that I use AC3 audio and refused to make a DVD if I tried to use PCM audio with MPEG-1 video. I don't know if you have to use AC3 with MPEG-1 or not, but Scenarist demanded it. Most authoring programs won't accept MPEG-1 video for DVD, but they should according to the specs. DVDLab has also been reported to accept MPEG-1 video for DVD creation.
