    Oct 2006
    Indonesia
    Hi, I'm new in Linux and FFMPEG. I need to know about command line when converting with ffmpeg. I'm run on Linux non-GUI, and I need to convert these video into smaller size, I know I will lose about quality. Here I want :
    1. AVI format -> Mp4 format
    2. MKV format - > mkv format
    What command line should I use and what codec should I choose for converting ?
  2. Member GMaq's Avatar
    Mar 2004
    Canada
    zirkov,
    Here's an example script for avi to .mp4 it is for an iPod but will convert an .avi to .mp4 for pretty much any purpose:
    ffmpeg -i (Pathtoyourfile).avi -f mp4 -vcodec mpeg4 -maxrate 1000 -b 700 -qmin 3 -qmax 5 -bufsize 4096 -g 300 -acodec aac -ab 192 -s 320x240 -aspect 4:3 (Pathtowhereyousavefile).mp4
    You can change the bitrate values and frame size/aspect ratio values to suit your needs. make sure your version of ffmpeg is compiled with mpeg-4 and/or XviD and aac support. There are documents on how to do this at this link for Ubuntu, You didn't say what distro you use.
    https://help.ubuntu.com/community/iPodVideoEncoding?highlight=%28iPodVideoEncoding%29
    Also look at AviDemux or WinFF that are both GUI front-ends for ffmpeg.
