  1. Banned
    May 2006
    Aafter downloading a XXX movie from torrents, it Unrar into a ISO file. I do Not want to burn the ISO file onto DVD or CD, but just want t o watch it on my PC and Delete it later.
    Try mounting it on a virtual drive , but all I got , when it opens into a Video TS File .
    Any program that converts an ISO File to a avi file or a WMP file?
    Apr 2004
    Miskatonic U
    The video_TS folder contains the DVD files required to view the movie. Open that with PowerDVD or Media Player Classic
    Read my blog here.
  3. Banned
    May 2006
    Okay, Thanks..Got it, I use Jet audio Plus
  4. Mod Neophyte redwudz's Avatar
    USA
    Usually VLC Media Player can open an ISO file directly and view it. It can also view a VIDEO_TS folder by selecting it by using 'Open Directory' or right clicking on the file and using the pull down menu.
  5. Banned
    May 2006
    can I also just burn that .iso image file on a DVD without converting anythimg and View it on my DVD Player?
  6. Mod Neophyte redwudz's Avatar
    USA
    Sure, if it's a valid DVD within that ISO container. Try dropping it into ImgBurn and you should be able to burn it. Make sure it is a NTSC not PAL or you may have problems playing it. PAL has a 25fps framerate, but Gspot will tell you that.
  7. Member buttzilla's Avatar
    Apr 2007
    Deep Space Nine
    You could also use a virtual drive. I use powerISO and just mount it in the virtual drive it creates then play it with your favorite player.
