Could someone tell me where I can get a H.264/MPEG-4 AVC codec. Preferably a single codec download. (For Vista)
As long as it doesn't have anything DivX related.
I would REALLY appreciate it. Thanks!
Results 1 to 13 of 13
I would also say Quicktime as it's free but I don't know how well it works within Vista yet.
FB-DIMM are the real cause of global warming -
Hey oh
Ok, I will say, I have apple quicktime installed. I have ffdshow installed. I have enabled, one at a time, all settings for mp4 in ffdshow with no effect on playback too. There is no working download link on the coreavc webstite. H.264/MPEG-4 AVC encoded (or any mp4 videos really) will not play on my computer. GSpot reports various reasons from unknown codec, missing codec, Codec Status Undetermined etc. for mp4 files.
What other option is there for playing H.264/MPEG-4 AVC encoded videos then?
Oh and yes, just this week I uninstalled ffdshow and quicktime and fresh downloaded and installed them JUST to be sure I hadn't missed out on an update. -
http://www.leadcodecs.com/Codecs/LEAD-H264.htm
http://www.elecard.com/
_________________"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Possibly you might need Haali's Matroska Splitter as is also can demux MP4-H264/AVC-files and feed it to either ffdshow, CoreAVC or Elecards H264/AVC-decoder. I use all three of them with no issues. PowerDVD also has H264/AVC-decoding abilities but its not free like ffdshow, which on the other hand still has problems with some CABAC- and or PAFF-encoded H264/AVC-videos like they are transmitted by some satellite HDTV-channels.
Good luck with your quest
Schmendrick -
could one of you gurus explain what this really means?:]
Because both the MOV and MP4 containers can use the same MPEG-4 codecs, they are mostly interchangeable in a QuickTime-only environment. However, MP4, being an international standard, has more support. This is especially true on hardware devices, such as the Sony PSP and various DVD players; on the software side, most DirectShow / Video for Windows codec packs include an MP4 parser, but not one for MOV.
In QuickTime Pro's MPEG-4 Export dialog, an option called "Passthrough" allows a clean export to MP4 without affecting the audio or video streams. One recent discrepancy ushered in by QuickTime 7 is that the MOV file format now supports multichannel audio (used, for example, in the high-definition trailers on Apple's site[10]), while QuickTime's support for audio in the MP4 container is limited to stereo.
http://en.wikipedia.org/wiki/QuickTime -
MP4 also can include multichannel audio like AAC-multichannel audio. Dolby-digital AC3-audio cannot be used directly. Someone on this or an other forum mentioned that AC3-audio can be multiplexed into MP4 as "private data stream", but I have not found a multiplexer/program capable to do this.
mpeg-4 AVC/H.264
By wingspar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 9th Dec 2009, 02:46 -
Converting H.264/MPEG-4 AVC to DVD
By KiteFlyer in forum Video ConversionReplies: 1Last Post: 23rd Jan 2009, 13:36 -
codec- H.264/MPEG-4 AVC Help
By spooky24 in forum Video ConversionReplies: 3Last Post: 12th Jan 2009, 18:04 -
MPEG-4 AVC/H.264 to SD-DVD?
By Killer3737 in forum Video ConversionReplies: 29Last Post: 2nd Oct 2008, 13:48 -
H.264/MPEG-4 AVC On Toshiba HD-A30
By hddvd2 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 08:12
