    Dec 2006
    Australia
    I may be behind the times, but in case others are too, I thought I'd post this information. I only had a copy of VideoStudio 7 and wanted to reverse a clip. I doesn't allow for that. Neither does Movie Maker.
    I searched the net and everyone seemed to be complaining that apart from high-end software that costs a fortune, no commercial software allows for this feature. I found some open source software that works, but is time consuming because of having to Import/Export and create text files.
    I then bought VideoStudio 9 (current version is 10) from eBay for $AU25.00 delivered (in Australia). It has a simple tick box called "Reverse". I'm a happy lad!
  2. Member Cornucopia's Avatar
    Using the "Reverse" filter (built-in) with AVISynth works just as well, if not better, for free.
    But I'm glad you found something you're satisfied with.
