Hi, I tried to find an answer in the forum but I couldn't, so if there is one I apologize for my incompetent search skills. Now, I have an original DVD which doesn't even have a closed caption. So I needed to write one my self. Luckily and strangely enough I found one in Dutch! So I had decent time code as far as the first part of the movie.VOB file goes.
So I started to translate with Subtitle Workshop. Since I don't speak the Dutch I started listen to the movie and change the sub accordingly. It was all good until the first VOB was ended. Obviously I was set to be punked when I loaded the second VOB. The time code wasn't continuing from where the first VOB left out! (Daa..) So I don't know which line is that I am editing now!
(I am sorry this is so long :=)
Now what am I suppose to do?
A) Am I to convert all the VOB files to one AVI, so that I can load it to Subtitle Workshop and sail away? How do I do that and should I worry about the possible sync problems?
I mean when I finish the sub and mux it back to DVD, will it be in the same time-frame zone as it's AVI counterpart?
Or B) Is there any other way to pull -this task- off without hurting myself?
Thanks a bunch before hand.
If you can do a half-assed job of anything, you're a one-eyed man in a kingdom of the blind.
Kurt Vonnegut -
Use a smaller font for yor next post. It's hard to read...
If your vob files are from one continuous movie, you can join them with a simple DOS command:
copy /b VTS_01_1.VOB + VTS_01_2.VOB + VTS_01_3.VOB fullmovie.vobGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
cemman,
You can also join VOBs with VOB2MPG and load that file into Subtitle Workshop.
Womble MPEG Video Wizard is great to open VOBs and join them to a single mpg file.
There are other ways as dicussed here:
https://forum.videohelp.com/topic240419.html?highlight=subtitle%20vob%20mpg
Problem listening super audio CD
By 1234567 in forum AudioReplies: 17Last Post: 22nd Nov 2011, 19:09 -
Question about software to write my own subtitles
By jimdagys in forum SubtitleReplies: 4Last Post: 4th Jun 2009, 10:53 -
write subtitles on movie vob
By mirceadima2004 in forum SubtitleReplies: 3Last Post: 6th Apr 2009, 15:55 -
divxmuxgui would write subtitles to play on wmp but not on vlc
By greendesert in forum SubtitleReplies: 1Last Post: 28th Sep 2007, 05:03 -
DVD has no Subtitles. How do I write my own?
By TRUSTpunk in forum SubtitleReplies: 10Last Post: 20th Jul 2007, 00:10
