    Jan 2002
    england
    i would be very greatfull if you could help me with this one,ive been at it now for over a mounth.ive bought the new panasonic dvd video recorder DMR-E20,it can write to dvd-r or dvd-ram.its the ram i am having problams with,ive writen 2 films of the television onto dvd-ram but i have no way of putting it onto dvd-r.i went out and bought a dvd-ram drive for the pc so i could read it,and it plays through power dvd or any other dvd software player.it is about 3.2 gig in size and it has the extension .VRO not .VOB ive changed the extension to .vob and writen it to a dvd-r and burnt it with nero but my player says it cant read this type of disk.have you any ideas if so i would be very greatfull, thanks
    speeedy
  2. YOU WILL HAVE TO USE ANOTHER BURNER NOT NERO TO BURN A MOVIE
    FILE. NERO ONLY BURNS THE DVD FILE AS A DATA (NOT MOVIE) FILE.
    YOUR COMPUTER PLAYS IT AS A DVD.MPG FILE NOT A MOVIE FILE. USE
    ULEAD GODVD , VIDEO STUDIO 5, OR SOME OTHER BURNING SOFTWARE.
    CHEERS
  3. Originally Posted by speeedy
    speeedy
    Hi Speedy:
    I have your machine too. And I also bought the Panasonic LF-311 DVR-R/DVD-RAM to transport my satellite recordings on the DMR-E20 over to my pc.
    Just download the VOB Filters and install them. Then you'll be able to open regular VOB's and the .VRO that the DMR-E20 creates with MediaPlayer, etc.
    Get it here:
    http://www.digital-digest.com/dvd/downloads/encoding_vobutils.html
    and download VOB Filters 1.04.
    I am currently starting to make VCD's from my DVD-RAM recordings on the E20.
    Jan 2002
    england
    ive tried ulead studio 5 and all it says is file format mismatch same as most other programs. :(
  5. Speedy,
    Were you able to solve your problem. I have the same one. I've tried DVDit!, Ulead DVD Workshop, Nero and many other programs with no result (mismatch...)
    Can anybody help with this?
  6. :D
    Proble is the VRO file is 702*576 instead of 720*576 and this with the AC3 sound fools a load of sw..
    DVDit will accept MP2 sound and the 702 size files so demux the audio and usae Besweet to convert to MP2 audio and then put them both into DVDit...
    Sound sync may be a problem ..
    Jul 2001
    Maryland
    Nero now burns DVD-Video
