I’ve been trying to convert several .AVI files to DVD format and burn them to a disk. Problem is, the conversion hangs within the first 2 minutes.
It is epidemic, I have tried several different source files, both .AVI and .MPGs and I’ve tried several different programs (Nero Vision, DVD Flick, Cyberlink, Womble DVD wizard) They all hang once they start encoding the video portion, usually I need to reboot.
I figure it is a codec problem, since that is only common element, but darned if I can figure out which one. Any suggestions?
I've got a tarball of the DVD flick output if that is of any use. There are no errors I can see, happily goes along until BOOM...
C>
Results 1 to 10 of 10
Tried convertx2dvd?
/Mats -
Try the convertXtoDVD. Works great. As for codec problem download KLcodec ful pack.This has all the codec's you'll need. And it usually will uninstall damaged codecs as it replaces them.
http://www.codecguide.com/download_kl.htm -
Nooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!As for codec problem download KLcodec ful pack
Do not install a codec pack. That way lies madness.
If you think you have broken codecs, use Codec Sniper or Filmerit to find them and remove them. If you think you have missing codecs, use G-spot to identify what you need and install only those codecs as required.Read my blog here.
I never ran into a problem with KLcodec but i'm gone check out the programs you recomended. What do you feel is the problem using a codec pack? I like to hear about your reasons for not. maybe you can convince me to stop using them.
No one can convince you to stop using anything...just know the more codecs you install the more probs will arise sooner or later....
To each his own!! whatever works!... even in space......Lol...." Who needs Google, my wife knows everything" -
This is the key thing. Sure, a codec pack may give you the *one* codec you need, but it will also load up a whole lot you don't need, some of which may create video viewing/decoding problems that you didn't have before. Why anyone would want to download and install something 98% of which they neither want or need is beyond me.Originally Posted by guns1inger
(Poor analogy): Kinda like trying to kill a fly with a shotgun. Sure, you may kill it, but you're almost guaranteed to do significant damage to your house
A better choice would be a flyswatter and some patience - task accomplished.
My 2 cents,
Jim
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 21:42 -
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 19:28 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 08:05 -
Problem converting MKV / MPG to DVD.
By smackyourfupa in forum Video ConversionReplies: 6Last Post: 24th Jan 2010, 05:55 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 05:30
