hi im trying to rip/extract digital wav. files through the internal pc dvd rom drive from sources such as DVD-movie (mpeg2) as well as AVI/DIVX
i would rather not have to extract the whole 2 hour movie audio file to get a 5 secnd clip, so please suggest something that will let me do this for specific clips or at least chapters.
I DO NOT want something that does RE-SAMPLING (such as http://www.roemersoftware.com/ )
cause these little programs simply record on the fly whatever comes out of your soundcard but unfortunately since they re-sample everything you also get the unwanted motherboard noise and all.
i really want an exact digital copy of the audio as it was recorded in the studio when movie was made.
thanx!
Results 1 to 10 of 10
Virtualdubmod,
Open video
Select start/Mark in and stop/Mark out (the buttons at the bottom center)
Last select Stream->streams list and select the audio track and click demux
Done. -
[quote="ted demen"]
/quote]
This is not a realistic goal. Although it is possible with various DVD rippers to only rip specific chapters, it's not possible to do this with AVI/Divx. You also can't tell any program which specific time indexes to only rip the audio between. You will need an audio editor to extract short clips from individual chapters that you rip from DVD and in the case of AVI/Divx, you'll have to rip the whole thing and then edit out what you want. -
thanx Baldrick,
seems like virtualdubmod is the one (although it doesnt preview avi files, and for some reason there is no sound when i load in a dvd, however after i save as wav, the sound is there)
oh and what about if i want to extract every chapter off a dvd, so i need to do it all at once or can i do all at the same time (i guess i can use dvd decrypter for that process in IFO mode?) -
i use sound forge as an editor.Originally Posted by jman98
on a side note, say i needed to rip the entire soundtrack off a dvd or avi...
what would be the quickest one click solution for that? -
For DVD I use Decrypter. For AVI, TMPGEnc Xpress will do the job, it wil also do DVD.
With Xpress you can also cut short clips only. -
some questions:Originally Posted by tinker
1. does it do short clips with just avi? or dvd (mpeg2) as well?
2. and does it re-sample through the soundcard converters? or is it a ripp/digital extraction?
3. and one last thing, if ripping off a dvd; can you do it in real time and straight from the drive by clip? (or do you first have to copy dvd to harddrive)
thanx
I was gone for a while, that is why no answer.
#1 Yes
#2 No, Yes
#3 If DVD not protected, than you can do it without copy to HD, but editing takes too long, not recommended. If DVD protected you have to rip it first.
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 23:18 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 08:03 -
Rip audio from avi
By tektaktyks in forum Newbie / General discussionsReplies: 8Last Post: 6th Jul 2007, 00:19
