I can understand from a uploader/downloader stand point to convert a full 4+ GB DVD to an avi file of 1+ GB......, OK now that I downloaded the 1.35GB avi file from a file sharing network or P2P, however the dimensions is only 640 X 360 or 640 X 480 and it's fine watching this avi movie on my LCD, however if I want to convert/burn this avi file to DVD so that I can watch it on TV OR if this avi file is already encoded with DivX and I have a DVD player that will play DivX file, will the pic quality of either these two scenarios will be as good as watching it on my LCD monitor?
Thanks in advance.
	Putting aside the legalities of uploading copyright material, and assuming, for the moment, that this is all above board, here are my thoughts.
 There is nothing to be gained by converting the avi back to DVD other than compatibility with a wider range of players. The video has been reduced in size, crushed and distorted by the subsequent encoding, and split in half. Converting it back to DVD entails resizing back up to DVD resolution, which will show up all the macro-blocking and banding introduced by the Divx/Xvid encoding, and then encoding with a lossy encoder. If you have a Divx/Xvid capable player then you gain nothing and risk losing quality by re-encoding.Read my blog here.
  dvd player wont play AVI or dvd video burned discsBy rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01
  Converting AVI to DVD using DVD Flick: low quality resultBy e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50
  Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 04:57
  Would this DVD player play AVI files burnt onto a blank DVD/CD?By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 20:38
  Best program for burning .avi to DVD for DVD Player, retaining quality?By Calcyon in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 01:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
