Hi, I am a complete newbie to video conversion and codecs. First of all I want to apologize if this is already posted someplace, I did do a quick search but never found what I am wondering. I understand that certain files require a certain codec to be played and know how to find and install them but thats about it. So, what I have done so far is I have an OGM file, lets say file1.ogm and an ssa file called file1.ssa. The ssa is considerably smaller than the ogm. Also, the ogm is dual audio, so it has Japanese and English both playing at the same time. I can play the file in Windows Media Player 11 with the RedLight OGG Media codec installed. I am wondering, how can I convert the OGM file to a AVI which has plain English playback. If anybody has any advice at all, that would be wonderful haha. Thanks a lot!
First: if you really must use Windows Media Player to play videos that have more than one audio or subtitle stream, you might want to install a splitter to allow you to choose between the audio streams (in AVI, OGM, MKV, MP4, etc.), like Morgan Stream Switcher, or better yet, Haali's Media Splitter.
The better choice would be to use a player that's better-equipped to handle videos with multiple streams, like Media Player Classic, VLC, mplayer, etc.
An OGM video is usually (at least, in my experience) an XVid AVI video stream (no audio), along with one or more Ogg audio streams (and maybe subtitle streams). I'm not as experienced with mencoder (apologies to celtic_druid
), so I use a different method.
Demux the streams from the OGM container using OGMDemuxer (a command-line tool, but you can create a shortcut to it on your desktop and drag OGM videos onto the shortcut). (You can also use VirtualDubMod for this, but I prefer using OGMDemuxer.
Find the audio stream you want to use, and convert it to MP3, if you prefer. Then load the AVI video stream in VirtualDubMod and add the audio stream to the AVI.
(Side note: the SSA file is an external subtitle file.)If cameras add ten pounds, why would people want to eat them?
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
How to merge .ssa and .avi with VideoDub?
By BlueMagneticMonkey in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2009, 15:55 -
.OGM and .SSA Combination
By Chaosfission in forum EditingReplies: 5Last Post: 7th Feb 2009, 04:33 -
How to put hard /ssa subs onto avi with AviDemux?
By chirufan in forum SubtitleReplies: 11Last Post: 7th Mar 2008, 15:33 -
When i join ssa+avi the video is messed up
By noskid21 in forum EditingReplies: 3Last Post: 17th Jul 2007, 14:02
