huh?Originally Posted by DereX888
Results 31 to 40 of 40
You were running XP without HHDs?Originally Posted by DereX888
Thanks. That was helpful. Mr google saysOriginally Posted by DereX888
Your search - "VISTA NEEDS HHDs" - did not match any documents. -
What it have to do with this thread?Originally Posted by BobK
well, do it american way - sue google!Originally Posted by BobK
To think that I installed a conventional SATA 300 in my Dell with Vista - when I coulda had a fancy Hybrid Hard Drive.
Oh well, I guess I'll get one of those when Buy, Fry's or Newegg decides to sell them.
Anyway, finally gave up on Vista - It crashed DVD Rebuilder.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I use DVD rebuilder on my vista laptop with no problem. Have you disabled windows defender realtime scanning? This was crashing some programs on me. Works fine now.Originally Posted by classfour
Version 1.20.4 pro -
Does nothing show in tasman when the local drive starts 'busyin' up'?Originally Posted by edong
We disabled the Indexing Service and it is "better" now. If it does it again, I will turn off some services one at a time to determine which one is the culprit. Task manager is showing only a few processes running so it might be easy to root out the offending program, if any. Thanks.
It does it again! And worse. The busy activity is now longer and more often than before. I turned off Windows Defender and AVG. No luck. I'm thinking this is hardware and not software related.
My Computer>Properties shows the processor is Intel 4300 dual 1.8Ghz (whatever that means) if that will help. -
I said it once in this thread... but maybe you missed it:Originally Posted by edong
get a Hybrid Hard Disk.
Your problem will be solved.
This behaviour is 'by design' in Vista, because it really is meant to run on HHDs.
If nothing will change in SP1 thats coming out, Vista still will be a 'standard' HD killer (literally). -
What a load of bollocks.Originally Posted by DereX888
I have Vista Ultimate running on a 1GB RAM + 150GB SATA hard drive. I don't get neverending disk access.
Using a hybrid drive can help with power consumption, hibernate and resume etc. But even a standard hard drive will have sufficient buffer RAM to prevent excessive disk access.
So what's a basic Tivo (read: DVD recorder with built-in Hard Drive) cost?
By snafubaby in forum DVD & Blu-ray RecordersReplies: 14Last Post: 18th Dec 2011, 12:53 -
Vista Partition Hard Drive
By ks47 in forum ComputerReplies: 3Last Post: 3rd May 2009, 07:09 -
Installing Vista on a Sata hard drive
By xtreemman in forum ComputerReplies: 11Last Post: 31st Dec 2008, 15:48 -
vista will not reconize 2nd SATA hard drive
By steve42069 in forum ComputerReplies: 3Last Post: 20th Mar 2008, 11:58 -
Modifying XP and Vista Partition Sizes on Single SATA Hard Drive
By Richkut in forum ComputerReplies: 1Last Post: 17th May 2007, 19:58
