Results 1 to 17 of 17
    May 2007
    I am having trouble trying to figure out how to use 7 zip to (unpack?) my RAR files 0-93 and how to create a playable video. I have downloaded 7 zip and it seems like a good program it's just that I am still wet behind the ears when it comes to video tech. I have looked on this site as well as some others to try to find a guide to figure this one out. Any help would be appreciated.
    Thanks....Crowheart
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    select all files and unpack .... burn img file
    May 2007
    Ok got you there. It seems like the very last file according to the test on 7-zip is broken. Is there a way to repair?
    Thanks....Crowheart
    Apr 2004
    Miskatonic U
    download it again
    Read my blog here.
    May 2007
    Good one very new,but not so stupid....
    Thanks....Crowheart
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Well....
    You asked.... he answered.....
    You can't make what is not there magically appear...
    Sometimes one part might get corrupted during DL.... if you don't delete anything and start the DL again sometimes it will just get the part that is messed up....
    Other times it was corrupted from the numbskull who thought it would be better to break something up into 30 rar files
    In that case you are usually screwed unless the guy redoes the one file that is messed up and reuploads it.
    May 2007
    Ok. What about a parity program? To fix the file? Just asking...
    Thanks...Crowheart
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Only if the parity file was made from the original, uncorrupted files.
    Read my blog here.
    May 2007
    Oh boy now I get it. Thanks...I wil not be using that again.
    Crowheart......
  10. Mod Neophyte redwudz's Avatar
    USA
    If it has a PAR file included, go ahead and try it. You may need a program like QuickPar to decipher and use them. Or you might luck out and be able to extract most of the file. I've done that occasionally with WinRAR by using the 'Repair archives' or 'Extract without confirmation'. I don't know if the freeware 7-zip has similar options.
    But, as mentioned, the best course is to re-download the file and hope you pick up the missing part.
    There seems to be less reasons to use RAR files these days with the many high speed connections available out there. Most people on dial-up would spend several days or much more to download a large video file. And with digital video, it only takes one small error to damage the file. Blame the uploaders for all that.
    May 2007
    I will attempt to repair, but not attempt to get this DL again. Thanks for the help....
    Crowheart..
  12. Banned
    Jun 2004
    Crowheart..
    Well you would not have to re-download the whole thing.... sometimes if you just restart the DL and save it to the same place it might just redo the part that is messed up.
    What even seem's stranger to me is when people make ONE big rar file for something and even when unrared it's not any bigger So what the heck is the point of even raring it
    To hide what's really in the file or what it really is!!
    Do i smell an attempted virus (just paranoid )
    Now 7-zip is cool!!!!!!
    When compressing a file to send to a friend, use winrar.... maybe a MB or two diff...
    Same with winzip...... now i crushed down a 130mb file to 25mb with 7-zip!!!!! and i've even seen 3-4gb files crushed down to 800mb with 7-zip!!!!!
    Unpacked they were the full 3-4gb and completely intact!!!!!!!
    Now that's what i call compression 8)
    And you can make the files to either open in winrar, winzip, ect. but the 7-zip format is the best i've seen so far and since discovering it a few months back, it's all i use if i need to, the only thing is i have to keep sending it to my friends to install so they can open stuff i compress
    Hopefully people will start using it more and more as time goes by... but then again... there are people i know who have had PC's for years and still don;t know what a zip file is let alone a rar file
  13. Mod Neophyte redwudz's Avatar
    USA
    I've only ran into a few files with the 7-zip format, but I was also impressed. RAR files are left over from the old 'dial up' days. (Though some are still stuck in that. Sorry. But with video, dial-up is not really a good option.)
    Of course with a few of the people out there putting up torrents from questionable sources, we aren't seeing the 'best and brightest' out there, either.
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    a lot of "fake" torrents are rar files also
  15. Banned
    Jun 2004
    Yep!!! I've only seen it a few times also, but i was blown away!!! thought it had to be BS or some kind of scam!!!
    But i was amazed!!
    That's why more people need to hopefully start using it.
    Even in the dialup days (which yes.. there are still people on dialup) video was not a good idea ever... day's at least, if not a week or two to get a 700mb file was insane!!!!!
    I remember waiting at least a week + for a cd sized file
    Where nowadays you can get a whole dvd in a few hours!!!
    More than a few 8)
    Hence my comment....
    I've never DLed one but i've seen many people complain and say they were not real and or virus infected......
  16. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Exactly why RAR is useful, it will tell you if the file is complete. A raw AVI file, just hope.
    Also, though RAR doesn't compress AVIs much if any, it's useful to wrap up other files in a package, info files, etc. I use it to archive AVI, AVS, cover images, and other authoring files in one neat file.
    Also useful to password protect a file. RAR encryption is pretty solid, there are only brute force dictionary attacks as far as I know.
    One nice application is to put a series of images (jpeg, png, etc) into a rar archive (eg book scans). This can be read as-is with CDisplay
  17. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Well, yeah, but you can do that with ZIPs, too. I use CDisplay all the time on both ZIPs and RARs. Too bad 7-Zip support couldn't be added...
