i have an avi movie and i use TMPGEnc to convert to mpeg2 and then i use TMPGEnc DVD author to make the VOB files. then i have nero but use DVD shrink to pop out my videos onto DVD. i've done this process tons of times. but this last video file is giving me so much crap.
everything goes smoothely until i get to the DVD shrink part. the audio is a good 2 seconds ahead of the video. i can't figure it out. the original file had no problems with sync. i even went through the whole process of converting 2 times and it's the same this. the only thing i can tell that's funny about the original avi file is that at the end, when the credits start to role, the audio cuts out. i figured the guy that made the video just wanted to save quality for the file size by taking some audio out. but i think this might be the root of the problem.
AVIcodec tells me this about the video file:
File : 702 MB (702 MB), duration: 1:56:36, type: AVI, 1 audio stream(s), quality: 40 %, ,
Video : 622 MB, 746 Kbps, 23.976 fps, 656*272 (2.41:1), XVID = XVID Mpeg-4, Supported
Audio : 80 MB, 96 Kbps, 44100 Hz, 2 channels, 0x55 = MPEG Layer-3, VBR, , Supported
maybe that'll help you help me.
Read my blog here.
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 22:09 -
Video and subtitle/sound sync problems in SubtitleCreator
By ditz in forum SubtitleReplies: 2Last Post: 20th May 2011, 04:12 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 04:10 -
DVD Video/Sound out of sync!
By bprobinson in forum Authoring (DVD)Replies: 0Last Post: 23rd Feb 2010, 15:51 -
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 11:48
