    Oct 2005
    Noob question i am sure but could someone kindly tell me the difference between x8 and x16 dvds as im looking to purchase some to do some burning.
    Thanks in advance
    David
    May 2003
    Peterborough, England
    It is the maximum speed they can be written at. Providing you have a modern writer woth up to date firmware, it will write 8x discs at 8x and 16x at 16x However, I have found that anything much faster than 8xis a bit of a waste as it only achieves maximum speed at the end of the burn, burning the majority of the disc at 8x then 12x and finally hitting 16x.
    Apr 2004
    The bottom of the planet
    Not exactly.
    Depending on the mode of burning used (constant angular or constant linear etc), the burning cycles through a lot of speeds. On most 16X media, DVDDecrypter will slowly and gradually increase from 8X to 16X over a period of several minutes. The average speed I usually get when burning 4.2 GB is about 14.5X, which is obviously quite a substantial improvement upon 8X.
    "It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
