This is more of an advisory for multimedia player programmers.
I have wrtten a multi format player app to play url content from the net which uses the v11 wmp.dll as one of the player plugins. The program worked fine but lately crashed anytime I tried to play a file from any url (not local on my hdd). The standalone wmp itself did not have this problem. I could run any wmp file from the net with no problem but not when using the plugin within VB. I know that MS just had an update to block a security flaw in the player so I suspected that it was causing problems. I checked the crash debug tracer log and found a reference to the Morgan Stream switcher ((a freeware Directshow filter which allows you to switch on the fly between several audio streams ). I removed it from my system and sure enough the wmp.dll now works flawlessly.
Hope this helps someone else who hits this bug. I will send a note to the author of the plugin. It may no longer be updated since I think, it was originally designed to work with version 9 of MS wmp.
Results 1 to 1 of 1
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 19:58 -
DVDMAESTRO sx32w2.dll
By twinegar in forum Authoring (DVD)Replies: 1Last Post: 16th Mar 2010, 13:04 -
MPEG2.dll
By Black-Logik in forum Video ConversionReplies: 6Last Post: 21st Mar 2009, 04:40 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
Nero 7 installed but no aac.dll or aacenc32.dll?
By AndyD in forum AudioReplies: 5Last Post: 13th Jan 2008, 19:28
