is there a way to convert .ts files to wma-hd??? so i can play them om my xbox360,or convert them to H.264???
Results 1 to 14 of 14
Will this work? if i run the ts file in HDTVtoMPEG2,and the in Total Video Converter whit the Mpeg4 h264 high quality profile?will i lose any quality?
First thing we need to do is determine if your TS file is h264 or MPEG2
Download TSremux
http://www.sendspace.com/file/bfoshw
Load your TS file into it (you don't need to mux, just need to get the info - like this)
Okay, you can convert them like this:
Install Quicktime Alternative v1.81
Download MpegStreamClip v1.1 for Windows http://www.squared5.com/svideo/mpeg-streamclip-win.html
is it norwal to use 8-10 hours to convert a ts file to H264 or mov using MPEG Streamclip?? any encoders that do the job faster,i have 7 big files to connvert so...
My fastest PC is a 2 year old one with a single core AMD 3200+ CPU. It takes me 24+ hours to encode to H.264, so I don't do it. Be very very glad it only takes you 8-10 hours. Do the encodes while you sleep.Originally Posted by Ducco
The forums at http://www.doom9.net have a discussion in the "New and alternative video codecs" section on converting HD MPEG-2 streams to WMV HD. You should take a look at this as there may be some information there that will help you.
Repair a WMA
By milo145 in forum AudioReplies: 9Last Post: 14th Dec 2015, 16:41 -
wma to cd
By jasoncolz in forum AudioReplies: 5Last Post: 2nd Apr 2011, 08:14 -
wma to mp3
By rjc7394 in forum AudioReplies: 5Last Post: 14th Sep 2010, 15:00 -
0x0161 (WMA v2)?
By uglijimus in forum AudioReplies: 11Last Post: 13th Mar 2009, 11:39 -
WMA-2.WMA-3 files conversion
By sumeshkri in forum Video ConversionReplies: 3Last Post: 27th Sep 2008, 20:52
