Just about to buy SONY MDSSP55 which is just the minidisc recording unit from a Hifi system (Sony CMT-SP55MD)
I have no HiFi to link this up 2, and as I need an amp to use speakers I was wondering If I would be able to use the amp in me DVD player (alba 103 or maybe 104 dunno which) and link it to the recoder via the optical out port.
if this is possible I have several questions...
1. Is this possible
2. Any comments about this setup
3. can I play it through my DVD aswell as use my DVD to record cd 2 minidisk
4. Nething else U think I might like to know like what else to get with it
Regards
AaRrGgHh AaRrGgHh2001@hotmail.com
well, i can tell you that yes, you can make cd to MD copies from your dvd player, as to what you're suggsting using the amp in your dvd player to play minidiscs, i don't really understand. i breifly owned an alba 103, and it didnt have an amp itegrated into it.....
ok first off, your dvd player would need inputs and outputs for this.
input to get your minidisc signal to the amplifier.
output to get your cd signal back to the minidisk.
if you only have an output on your dvd player, you will not be able to amplify the signal. you will only be able to record your cd tracks to the minidisk.
mic -
Cheers for that - Not really big on the technology on DVD players or minidisc players - so could ne one tell me if the alba 103 and 104 has inputs and outputs for this?
Regards
AaRrGgHh
minidisc
By magillagorilla in forum AudioReplies: 29Last Post: 26th Aug 2011, 18:11 -
Linking to the web with DVD Lab Pro 2
By V879 in forum Authoring (DVD)Replies: 6Last Post: 1st May 2011, 10:31 -
HD DVD copying from minidisc to regular
By Isla in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2010, 12:55 -
Linking website to DVD
By bsanti in forum Authoring (DVD)Replies: 3Last Post: 25th Jan 2008, 08:28
