    Sep 2006
    Hi,
    I have just tried to re-render an AVI file in Pinnacle Studio. This was originally captured from a DV tape, loaded into Studio, edited and rendered to a DVD. All worked fine. 6 months later, I have returned to it to try to produce a version suitable for the web (my wife wants to put a bit of it onto UTube). Now the audio track plays like it is much too slow -out of sync with the video and much lower in tone. I have NOT done anything to the original .avi file but only have Pinnacle Studio (v10) to play it through. Any suggestions as to what the problem might be and any solutions would be very gratefully received. I have lots of other similar .avi files and they all work fine in Studio, so I don't think that can be the problem.
    Thanks,
    Chris
    Oct 2005
    666th portal
    right click on the file and open with any software media player. should load and play with just about anything. might be something slowing down your entire computer not just p.s. use task manager to check.
