I have a Pinnacle studio PCTV Pro. Whenever I use virtualdub to capture from tv (ntsc), in higher than vcd resolution, I get these weird horizontal lines. They are especially prominent around text and with movement. Is this a limitation or is there some setting to fix it? I had the same problem when ripping one of my dvds to xvcd before. It had to do with "ntsc film" or some setting in DVD2AVI, IIRC. I'd appreciate any help or comments on the situation. Thanks
I haven't had much luck with the deinterlace filters in VirtualDub, any other way to combat these interlace lines?
Dark Horizontal Lines
By daave in forum Capturing and VCRReplies: 4Last Post: 14th Aug 2012, 16:26 -
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 11:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 11:23 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 20:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 13:06
