I have the .vob files of a movie on my computer. When I play the files directly on the computer, they play fine. When i burn a DVD using the same files, it plays the DVD fine on my computer. However, no matter what software I use, the type of DVD, or the different burning speeds, the DVD always skips every couple minutes on the DVD player on my tv. I have tested it on 3 different players, using different types of DVD's and speeds, but it always skips. I am all out of ideas. Any help would be appreciated. Thanks!![]()
Results 1 to 15 of 15
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Try opening it with DVD Shrink, just to see if it is intact. Shrink can be pretty picky if things aren't right. If it fails, run it through FixVTS and try again.
Read my blog here.
Thanks for the replies guys i will try the suggestions when i get back home and post my results. Thanks!
EDIT: What are the options i should be using with the demux program? -
...What are the options i should be using with the demux program?
That depends a little bit on your source.
Try this guide:
https://www.videohelp.com/guides/simplistic-guide-for-replacing-dvd-streams-flash-id937#937GUI for dvdauthor:
Sounds like all you need is better media - use Taiyo Yudens or Verbatims. Verify your burns and do a PIPO check afterwards. Ensure your DMA is on, too.
Maybe clean your drive, too.
RegardsLes -
If it plays OK on your PC software player, you got a problem with the burn or your standalone. No amount of demuxing, remuxing, fixing VTSs etc will help. Please see my previous post.
RegardsLes -
No, these two are enough.Originally Posted by oinkyboinky
I assume, that you have already created other DVDs with your drive and your media, which do not show this kind of skipping?
Otherwise blutach is probably right with with suggestion...
Have you tried guns1inger suggestion (dvdshrink) already? This would be much more simple...
If you want to go the demux/remux way, in very short:
Open pgcdemux and set an output folder, the 'Input IFO' is the VTS_01_0.IFO file in your VIDEO_TS folder (if you have several VTS_XX_0.IFO files, the process gets more complicated...), use Mode: by PGC, set a tag at the options:
Demux video stream
Demux all audio streams
Demux all subpic streams
Create CellTimes.txt
PGC Selection - Domain: Titles
and click on Process!
If there are several PGCs, you need to process each one into a different output folder and things are getting more complicated, as these would need joining. Otherwise (only one PGC) open MuxMan and select the VideoFile.m2v from your pgcdemux output folder as video, the AudioFile(s)_XX... as audio file(s) and the sup files as subpictures. Select 'File - Import Chapter' from the menu in MuxMan and select the Celltimes.txt from your pgcdemux output folder. Set up a destination folder and click start.GUI for dvdauthor:
Thanks for the suggestions, and here's a little update. I bought some verbatim dvds, and burned at a slow speed, but the skipping is still there. Any other ideas?
...but the skipping is still there.
Only for a particular title, or for every DVD you burn?GUI for dvdauthor:
Other files work fine. It is these specific .vob files i am having trouble with.
If demux + remux doesn't help, then there is probably something wrong with the video/audio streams. Sometimes the only way is reencoding the streams. There are a lot of guides available for this purpose. I would start with the demultiplexed m2v from pgcdemux and tmpgenc, hc or cce to encode the video only. If remuxing the new video with the 'old' audio stream(s) is ok, keep it. Otherwise transcode the audio too (first to wav and then to AC3).
GUI for dvdauthor:
Help with burned DVD's skipping
By BDrums1971 in forum Newbie / General discussionsReplies: 20Last Post: 1st Sep 2013, 16:06 -
Audio is skipping when I play videos that are burned on a Data disc DVD!
By Xenogear900 in forum Software PlayingReplies: 8Last Post: 23rd Mar 2009, 14:12 -
VOB files skipping
By Mindg in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2007, 23:27 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26 -
avi files burned to dvd skipping...any idea why
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 8th Jul 2007, 03:10
