    Jan 2004
    Queens
    I get this error while trying to burn a dvd using IMGBurn, "Your image doesnt appear to be the correct formatfor burning onto a DVD. Image format: MODE1/2336, DVD format: MODE1/2048, WOuld you like to continue anyway?"
    If I hiot yes, then it will burn but it will not play with my dvd player. I use TaoYuden disks. Nevber had this problem before. Can anyone help. Thanks
  2. Member blutach's Avatar
    Apr 2007
    Australia
    Upgrade to version 2.3.2 It's been out for a while to correct this bug.
    Regards
    Les
    Jan 2004
    Queens
    thank you I thought i had the update. Thanks
