I'm trying to "demux" an old vob file that I stored on an archive disc, so it will load into DVDAuthor. I've tried both DVD Decrypter, and VOB2MPG (BadgerIT), but both of them require the vob file to be nested within a VIDEO_TS directory with an IFO image file. I managed a workaround, by renaming and swapping vob files in a hard drive directory, then using Nero to write them to a blank DVD, then using VOB2MPG. But, my system didn't like that "forced" approach, it gave me "virtual memory is low" error messages, and it took more than an hour for a short file.
Is there any simple way to demux a "naked" vob file on a hard drive (which will play properly, with sound, on a player such as PowerDVD) to create a mpeg, m2v, or similar demuxed video file? If so, what software? Or, if DVD Decrypter will do it, what settings or steps to I need to use?
BTW, I do NOT want to go through an avi conversion (using Flask, etc), and then have to go through a compression step. That leads to losses. I want a clean and lossless conversion, via a simple demux.
Can anyone help? Thanks.
BatchDemux !
or
tmpgenc, under file mpeg tools and demultiplex.
dgindex
https://www.videohelp.com/tools/sections/video-de-multiplexers
Output of both m2v AND ac3 during single "Render As" event in Vegas?
By Smells_Like_Feet in forum EditingReplies: 3Last Post: 28th Oct 2011, 20:08 -
"Could not find any VOB unit in VOB file(s)" - Using Ifoedit
By devilcoelhodog in forum Authoring (DVD)Replies: 1Last Post: 1st Feb 2010, 23:01 -
authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files
By ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31 -
Demuxing Smartripped VOB with VobEdit06... M2V won't play in VLC?
By Iceblade in forum Video ConversionReplies: 12Last Post: 15th Oct 2007, 23:30 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
