Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    May 2007
    This relates to my nephew's laptop so don't go off the 'spec' that I have listed. All I know is he has a Toshiba laptop which is one of the more expensive models. All movies he is burning on his laptop play as a very very thin letterbox mode ( no more than about 6-8" high on the screen) when he plays them on any dvd player. He has to use the zoom button to make the picture bigger which distorts the picture massively. He has Nero which I think came 'bundled' on his laptop and has also tried Mcfunsoft dvd maker. Both give the same results. He has tried different settings on these two programs but the results are the same. Anyone have any ideas?
    Many thanks.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Have him drop one of the videos into Gspot 2.70 and see what it reports as the framesize and the aspect ratio. The one shown is 4:3 and NTSC format. Nero is not a very good encoder and I haven't used the other product. What is his source for the videos? There are a lot of programs that will do better than Nero. See our 'Tools' section.
    May 2007
    Mcfunsoft is just a very simple, cheap and chatty dvd maker you can download off the internet. I only mentioned it because I suppose if it's two dvd makers that are creating the same result then it has to be something in his laptop. As far as I am aware this happens with any video file he tries to put to disc, ie, his own, video off the internet, swopped video, etc. And as i said, it is a VERY narrow letterbox. I've certainly never seen a letterbox format this narrow. I never thought about Gspot. I'll get him to put it on his laptop and do what you say. At least its a start in the right direction to see whats going on and if it does say 4:3 for instance then we know the problem is elsewhere. Many thanks.
