When I try to join 2 AVI files, each around 700MB, either with NeroVision, or Virtual Dub..I run out of room on my hard drive because the output file it's trying to create (an AVI file) is over 120G!!
What am I doing wrong?? Why is this happening all the time? All I'm trying to do is join two avi files. It also is taking 1.5 hours to do.
Any suggestions?
Don't hijack threads. Start a new thread for a new question please.
You're saving it out as uncompressed AVI, which as you've noticed is huge.
You should set both audio and video to direct stream copy to keep the compression of your original (or use full processing, and select and configure the codec).
/Mats -
File -> Open Video File
File -> Append AVI Segment
Video -> Direct Stream Copy
File -> Save as AVI -
Sorry bout that Mats. Thanks for the quick replies! I'll give it a whirl.
noise where joined 2 avi files
By coyote2 in forum EditingReplies: 20Last Post: 13th Oct 2011, 21:19 -
Joined avi's have no audio
By junee in forum MacReplies: 5Last Post: 5th Feb 2010, 20:40 -
Joined 3 AVI Videos using Avidemux, but 1 video has sound, other 2 don't??
By UmmAddan in forum EditingReplies: 2Last Post: 31st Dec 2007, 18:04 -
Joined avi file conversion problem
By siberian50 in forum MacReplies: 12Last Post: 26th May 2007, 19:04
