Hi, hope to find help here: Have succeeded in converting MOV into FLV, but the resulting file has some additional white frames at the end. I tried to shorten the MOV, but with the same result. Any ideas? Thanx in advance, Joerg
I've noticed the same thing. If you use ffmpegx to encode an FLV, it adds an extra two frames to the runtime which appear as white frames if viewed in QuickTime --AND-- black frames if viewed via Flash's media component in a browser.
For example if the original clip's runtime is: 00:00:41.00 @ 25 fps the FLV's runtime will be 00:00:41.02 @ 25 fps
Definitely a minor bug.
Slight Pause at the End of Each Clip (MTS files)
By Obtong in forum EditingReplies: 4Last Post: 9th Aug 2011, 23:53 -
White screen at end of trimmed videos - AviDemux 2.5
By BobAchgill in forum EditingReplies: 0Last Post: 6th Aug 2010, 23:12 -
Pryo DV capture adds tons of blank frames in between dropped ones.
By Knightmessenger in forum Capturing and VCRReplies: 11Last Post: 18th Jul 2009, 16:08 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09
