Gday to all
The problem i have is happening more and more often ,
screen will go black then come back on and all the colours and grafix are then all screwed up
and on occasion the whole system will shut down and restart. mostly when you are using it but sometimes when its just on, then again I'ive been on now for over 1hr and it has not happened.
what iv done to try and fix it is
installed a new HDD and reinstalled the OS win xp pro
made sure the refresh rate is correct for the moniter.
i dont think its the monitor as i have another pc hooked up to it and it works fine
any ideas
im thinking video card but hard to check without a replacement
the card is NVIDIA GEforce4 MX 440-se
the rest of the unit is
P4 1.7
160gb HDD
Gigabyte P4 titain 667 mother board
768 ram
winxp pro SP2
yes its an old bus but it just keeps on truckin
used mostly for internet and email
and some old games not many
thanks in advance
	Have you downloaded the latest drivers fron nvidia site .... yes its an old graphics card but the drivers are still updated (i have a pc with the same card in) ... also try opening the pc and removing the card and then reinsert it as there could be a bad connection with the agp slot (seen this so many times and just removing the card and reinserting it usualy does the trick) ... also make sure there are no cables running close to the card ... i noticed that my mx 440 did funky things when one of my ide cables was very close to it.
 If it still has a problem after trying all the above then its probably a faulty card ... get a new one
  Looking for new driver for video card- MEDION (7134) WDM Video Capture cardBy 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48
  video card problem causing watching movies problem?By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39
  Video Card TV-Out problem...By ToastMan85 in forum Media Center PC / MediaCentersReplies: 0Last Post: 16th Dec 2007, 13:13
  video card problem?By alintatoc in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2007, 12:25
  new video card problemBy Silverknight in forum Software PlayingReplies: 5Last Post: 7th Aug 2007, 20:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
