i am converting some t.v. shows that are in mp4 format to avi, using Super, my question is what bitrate should i use in the "video" bitrate selection, is their a standard, it goes from 64 to almost 10000
If you are converting them to avi to play on a Divx capable player then you probably don't need to resize them bigger than 640 x nnn. The player will do the rest. Bitrate comes down to running time and quality. For a 42 minute TV episode, 350 MB should produce acceptable quality if well encoded. This gives you a video bitrate of around 944 kbps with 128 kbps audio.
If you are converting to DVD then you will get 2 - 3 42 minute episodes to a disc at acceptable quality at full-D1 at a bitrate of around 4300 - 6500 kbps (longer running time, lower bitrate).
If your player cannot playback Xvid type avi files then you will have to convert to mpeg2 and author for DVD. In that case, do not convert to avi first.Read my blog here.
Video bitrate incorrect in Super
By lemmy999 in forum Video ConversionReplies: 2Last Post: 1st Jul 2011, 22:13 -
mp4 to avi using SUPER
By jjbodean1970 in forum Video ConversionReplies: 3Last Post: 4th Sep 2008, 23:49 -
Convert MP4 to WMV using SUPER
By bdr13278 in forum Video ConversionReplies: 6Last Post: 21st Aug 2008, 12:19 -
Bitrate and Video Conversion with Super
By Excelsior123 in forum Video ConversionReplies: 1Last Post: 28th Mar 2008, 21:03 -
using SUPER to convert a DVD to MP4
By snafubaby in forum Video ConversionReplies: 1Last Post: 8th Aug 2007, 15:43
