  1. Before I go off and freak out on those people at VSO, thought I'd ask you gurus first. Here is my question list...
    1. When burning an AVI file, does it have to be a correct format to work on my DVD player? A lot of AVI files I've burned work real well, perfectly actually.. but then some don't work at all. could this be a result to what kind of compression was used on it?
    2. If i take these avi files... and recompress them to DivX format with say.. VirtualDub and then burn them (in DivX format..) will that work?
    3. see anything wrong in this latest log...?
    5/12/2007 2:28:25 AM info ********** Report session closed ***********
    5/12/2007 2:24:13 AM info Finalization Time 00:00:43 - Total completion time 00:09:10
    5/12/2007 2:23:30 AM info Write finished in 00:08:26 - Finalization start here. Avg. burn rate 7.22
    5/12/2007 2:15:19 AM info Lead-in burning time (mS) 15685
    5/12/2007 2:15:03 AM info Write started 2250720 sectors to write
    5/12/2007 2:15:03 AM info Init success: DVD-R packet writing
    5/12/2007 2:15:03 AM info Writing speed requested x8.0, effective x8.0
    5/12/2007 2:15:00 AM info Available write speed: 16x, 12x, 8x, 4x
    5/12/2007 2:15:00 AM info Media ID: SONY16D1
    5/12/2007 2:15:00 AM info Media type: DVD-R
    5/12/2007 2:14:59 AM info Scanned files #10, folder #2 - total size 4608352256 b. (4.29 Gb.)
    5/12/2007 2:14:59 AM info Inserted media type : DVD-R
    5/12/2007 2:14:59 AM info Write started
    5/12/2007 2:14:57 AM info --------------Encoding end--------------
    5/12/2007 2:14:57 AM info Media name: "XXXXXX"
    5/12/2007 2:14:57 AM info Burned folder: "C:\Users\Brett\Documents\ConvertXtoDVD\XXXXXX\"
    5/12/2007 2:14:54 AM info New media inserted. Burning layer is ready to write
    5/12/2007 2:14:52 AM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
    5/12/2007 2:14:52 AM info New Drive selected : 0:1:0 - TSSTcorp DVD+-RW TS-H553A DE04 [D] (Raid)
    5/12/2007 2:14:51 AM info Total size in built folder 4394 Mb., Target size DVD5 4400 Mb., Occupation 99.88%
    5/12/2007 2:14:51 AM info Conversion completed in 01:43:45
    5/12/2007 2:14:37 AM info ------------Converting Menu--------------
    5/12/2007 2:14:37 AM info Generated duration 8183.96 sec., expected 8184.00 sec.
    5/12/2007 2:14:37 AM warning P-SDT buffer Underflow 1 times, 541 bytes peak
    5/12/2007 2:13:42 AM info Chapter #28 start at 134:59.880
    5/12/2007 2:10:10 AM info Chapter #27 start at 129:59.640
    5/12/2007 2:06:27 AM info Chapter #26 start at 125:0.120
    5/12/2007 2:02:45 AM info Chapter #25 start at 119:59.880
    5/12/2007 1:59:01 AM info Chapter #24 start at 114:59.960
    5/12/2007 1:55:18 AM info Chapter #23 start at 110:0.040
    5/12/2007 1:51:37 AM info Chapter #22 start at 104:59.800
    5/12/2007 1:47:50 AM info Chapter #21 start at 99:59.680
    5/12/2007 1:44:07 AM info Chapter #20 start at 94:59.800
    5/12/2007 1:40:25 AM info Chapter #19 start at 90:0.040
    5/12/2007 1:36:42 AM info Chapter #18 start at 85:0.000
    5/12/2007 1:32:56 AM info Chapter #17 start at 79:59.960
    5/12/2007 1:29:11 AM info Chapter #16 start at 74:59.760
    5/12/2007 1:25:25 AM info Chapter #15 start at 70:0.000
    5/12/2007 1:21:41 AM info Chapter #14 start at 64:59.920
    5/12/2007 1:17:59 AM info Chapter #13 start at 60:0.080
    5/12/2007 1:14:15 AM info Chapter #12 start at 54:59.680
    5/12/2007 1:10:32 AM info Chapter #11 start at 49:59.640
    5/12/2007 1:06:48 AM info Chapter #10 start at 44:59.880
    5/12/2007 1:02:58 AM info Chapter #9 start at 40:0.080
    5/12/2007 12:59:14 AM info Chapter #8 start at 34:59.680
    5/12/2007 12:55:29 AM info Chapter #7 start at 29:59.960
    5/12/2007 12:51:41 AM info Chapter #6 start at 24:59.960
    5/12/2007 12:47:53 AM info Chapter #5 start at 19:59.920
    5/12/2007 12:43:51 AM info Chapter #4 start at 14:59.840
    5/12/2007 12:39:34 AM info Chapter #3 start at 9:59.800
    5/12/2007 12:35:19 AM info Chapter #2 start at 4:59.920
    5/12/2007 12:31:06 AM info Stream #1 Sync. delay : 0.00 ms
    5/12/2007 12:31:06 AM info Stream #0 Sync. delay : 0.00 ms
    5/12/2007 12:31:06 AM info Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s, no automatic gain control
    5/12/2007 12:31:06 AM info Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=1-31, 4213 kb/s
    5/12/2007 12:31:06 AM info Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
    5/12/2007 12:31:05 AM info No pulldown: Frame duplication/removal will be used.
    5/12/2007 12:31:05 AM info Video source original frame rate: 25.00
    5/12/2007 12:31:05 AM info PAL 25 FPS output format set automatically
    5/12/2007 12:31:05 AM info Widescreen (16:9) set automatically
    5/12/2007 12:31:05 AM info Video bitrate 0/4213/8808 Kbps (min/avg/max)
    5/12/2007 12:31:05 AM info Converting "C:\Users\Brett\Desktop\XXXXXX.avi"
    5/12/2007 12:31:05 AM info ----------------Title #1----------------
    5/12/2007 12:31:05 AM info Project size 4.3 Gb. (191 Mb. audio - 4.1 Gb. video)
    5/12/2007 12:31:05 AM info Stream #1 - Audio: mp3, 48000 Hz, stereo, 112 kb/s
    5/12/2007 12:31:05 AM info Stream #0 - Video: mpeg4, yuv420p, 480x256
    5/12/2007 12:31:05 AM info 2 Stream(s) found - est. duration 02:16:24.000
    5/12/2007 12:31:05 AM info Opening file "C:\Users\Brett\Desktop\XXXXXX.avi"
    5/12/2007 12:31:05 AM info [ ] Don't fix audio gaps
    5/12/2007 12:31:05 AM info [ ] Engine Log
    5/12/2007 12:31:05 AM info Encoder quality: 100%
    5/12/2007 12:31:05 AM info --------------Encoding begin--------------
    5/12/2007 12:31:05 AM info --------------Menu settings end--------------
    5/12/2007 12:31:05 AM info [ ] Sequential playback
    5/12/2007 12:31:05 AM info [ ] Loop playback
    5/12/2007 12:31:05 AM info [X] Auto start playback
    5/12/2007 12:31:05 AM info [X] Menu
    5/12/2007 12:31:05 AM info --------------Menu settings begin--------------
    5/12/2007 12:31:05 AM info --------------Default burn settings end--------------
    5/12/2007 12:31:05 AM info Default speed selected: 8x
    5/12/2007 12:31:05 AM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
    5/12/2007 12:31:05 AM info New Drive selected : 0:1:0 - TSSTcorp DVD+-RW TS-H553A DE04 [D] (Raid)
    5/12/2007 12:31:05 AM info [ ] Delete files after burn complete
    5/12/2007 12:31:05 AM info [ ] Don't eject after burn complete
    5/12/2007 12:31:05 AM info [ ] Prefer SAO for DVD-R
    5/12/2007 12:31:05 AM info [ ] Include originals
    5/12/2007 12:31:05 AM info [X] Burn result to DVD
    5/12/2007 12:31:05 AM info --------------Default burn settings begin--------------
    5/12/2007 12:30:01 AM info User default language : 1033 (0x0409h) - English (United States)
    5/12/2007 12:30:01 AM info System default language : 1033 (0x0409h) - English (United States)
    5/12/2007 12:30:01 AM info Version 2.1.18.242
    5/12/2007 12:30:01 AM info ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
    5/12/2007 12:30:00 AM info OS : Microsoft Vista Professional (Build 6000)
    5/12/2007 12:29:58 AM info ******************** Report session started ********************
  2. Just opened my file with gspot and the Frames per second are 25. i don't remember ever setting the frame rate when taking these videos off my cam corder.. But it makes sense because it was purchased in china.. So.. Could that be why it is working in my Computer (region free...) and NOT in my standalone DVD player?
    and if so... would CX2DVD burn it for NTSC for me?
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If you leave Format set to auto then 25 fps (PAL) source will be encoded to 25 fps (PAL) output. If you want NTSC, set it to NTSC. Most likely your player simply won't play PAL material - not uncommon with NTSC kit.
    BTW - impressed your camcorder could film the Shawshank Redemption.
    Read my blog here.
  4. Well it is a very bad ass cam.......
    it was a video file straight off the camera that i converted to AVI. so youre probably right... cant play PAL. THANKS!
