Hello,
I try to make a huge slideshow of around 1000 photos and videos to burn on a DVD.
I use the great tool "DVD Slideshow GUI" to create the slideshow, then I export it to an AVS file.
The AVS file is quite big (1268 Ko). When I try to open it (via VirtualDubMod or Quenc), then I have an avisynth error about insufficient memory.
I could make 3 or 4 slideshows and avs files, encoding them then joining the mpeg files.
But is there another way to bypass insufficient memory with Avisynth ?
Is it possible to split an avs file ?
Thank you for your help!
Results 1 to 9 of 9
That's a lot of pics, but you can try adding the following to the top of your AVS script:
SetMemoryMax(512)
or whatever # is 1/2 the amount of your installed RAM -
Hello Soopafresh,
Thank you for your response.
I tried SetMemoryMax, but the same error occured...
I opened the task manager and I have seen that there is a bigger and bigger exchange file that is created when the avs file is loaded in VirtualDubMod. At one time, the exception is raised.
I have set the exchange file to the maximum allowed by Windows (4096 Mo), but the error raised at around 1.9 Go of the exchange file.
So I have a problem of virtual memory, even if it is set to max.
Any other hint/workaround ?
Thank you! -
Post an extract from the beginning of your AVS file.
That may suggest the problem and hopefully solution. -
Here it is
If you want, I have attached the avs file that is generated (1Mo)
SetMemoryMax(256)
# Script gererated by DVD slideshow GUI
loadplugin("C:\Program Files\DVD slideshow GUI\Transitions\TransAll.dll")
loadplugin("C:\Program Files\DVD slideshow GUI\bin\vsfilter.dll" )
loadplugin("C:\Program Files\DVD slideshow GUI\bin\zoom.dll")
# Definitions:
SafeH = 400
SafeW = 720
overimg=blankclip()
SafeAviH = multifour(400) # resizing avis within width and height
SafeAviW = multifour(720)
# Import of background image - the proportions of this will be the proportions of the final film.
bname = "background_golden.jpg"
SafebH = 400 # resizing background within width and height
SafebW = 720
rate = 30
bname = LanczosResize(imagesource(bname,1,1,rate),SafeBW,s afeBH)
a = bname
at = bname
b = bname
bt = bname
# Import of audiotrack to be faded out with last still
audiotrack = DirectShowSource("D:\Mp3\music.mp3", fps=30).eqaudio()
am = bname
am = loop(am,int(30*(audiotrack.AudioLengthF/audiotrack.AudioRate)))
music = AudioDub(am,audiotrack)
imgout=ImageSource("D:\Martinique\Martinique_avs_t emp_files\Martinique_avs%06d.ebmp", 0,1065, rate)
SafeH = 400
SafeW = 720
# The filename and location of the exported ssa file with subtitle values for each text.
ssa = ""
writefilestart(blankclip(),"C:\Program Files\DVD slideshow GUI\DVDsGUItemp"+".ssa","ssa",append = false)
ssafile = "C:\Program Files\DVD slideshow GUI\DVDsGUItemp_subtitles.ssa"
ssa = ssa + "[Script Info]"+ chr(10)
ssa = ssa + "ScriptType: v4.00+"+ chr(10)
ssa = ssa + "Collisions: Normal"+ chr(10)
ssa = ssa + "PlayResX: 384"+ chr(10)
ssa = ssa + "PlayResY: 180"+ chr(10)
ssa = ssa + "Timer: 100.0000"+ chr(10)
ssa = ssa + chr(10)
ssa = ssa + "[V4+ Styles]"
writefilestart(BlankClip(),"C:\Program Files\DVD slideshow GUI\DVDsGUItemp"+".ssa","ssa",append = true)
ssa = ""
ssa = ssa + "Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, "
ssa = ssa + "Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding"
ssa = ""
ssa = ssa + "Style: Default,Times New Roman,20,&H00FFFFFF,&H0000FFFF,&H00000000,&H000000 00,0,0,0,0,50,50,0,0.00,1,2,0,2,20,20,20,1"
ssa = ""+ chr(10)
ssa = ssa + "[Events]"+ chr(10)
ssa = ssa + "Format: Layer, Start, End, Style, Actor, MarginL, MarginR, MarginV, Effect, Text"+ chr(10)
ssa = ""
# PROGRAM
inpoint = 1
a = DirectShowSource("D:\Martinique\NTSC/20011231190026.avi").converttoyv12().AddBorders(10 , 10, 10, 10, $FFFFFF).eqaudio()
awav = DirectShowSource("D:\Martinique\NTSC/20011231190026.avi", fps = 30).eqaudio()
aviname = SafeSize(LanczosResize(a,Width(a)*1,height(a)*1),S afeAviW.multifour,safeAviH.multifour,rate)
backname = loop(bname,a.framecount)
a = converttoyv12(AddBack(aviname,backname,1).Has169() )
at = trim(a, a.framecount-1, a.framecount)
at = loop(at,25)
awav = awav.HasAudio() ? awav : audiodub(a,BlankClip(length=a.framecount, fps = rate, audio_rate=48000, stereo = true))
a = audiodub(a,awav).eqaudio()
at = audiodub(at,BlankClip(length=at.framecount, fps = rate, audio_rate=48000, stereo = true))
inpoint = a.framecount+at.framecount
outpoint = a.framecount+at.framecount
b = DirectShowSource("D:\Martinique\NTSC/20011231190026_jobcontrol.avi").converttoyv12().eq audio().AddBorders(10, 10, 10, 10, $FFFFFF)
bwav = DirectShowSource("D:\Martinique\NTSC/20011231190026_jobcontrol.avi", fps = 30)
aviname = SafeSize(LanczosResize(b,Width(b)*1,height(b)*1),S afeAviW,safeAviH,rate)
backname = loop(bname,b.framecount)
b = converttoyv12(AddBack(aviname,backname,1).Has169() )
bt = trim(b, 0, -1)
bt = loop(bt,25)
bt = audiodub(bt,BlankClip(length=bt.framecount, fps = rate, audio_rate=48000, stereo = true))
bwav = bwav.HasAudio() ? bwav : audiodub(b,BlankClip(length=b.framecount, fps = rate, audio_rate=48000, stereo = true))
b = audiodub(b,bwav).eqaudio()
c = converttoyv12(Dissolve(at,bt,25))
c = audiodub(c,BlankClip(length=c.framecount, fps = rate, audio_rate=48000, stereo = true))
d = a + c
d = pointchk(inpoint, outpoint) ? d : d.trim(0,inpoint)+audiodub(d.trim(inpoint,outpoint ),fadeout2(audiodub(d.trim(inpoint,outpoint),music .trim(inpoint,outpoint).fadein2(at.framecount)),at .framecount))
a = DirectShowSource("D:\Martinique\NTSC/20011231190026_jobcontrol.avi").converttoyv12().eq audio().AddBorders(10, 10, 10, 10, $FFFFFF)
alength = a.framecount
awav = DirectShowSource("D:\Martinique\NTSC/20011231190026_jobcontrol.avi", fps = 30).eqaudio()
aviname = SafeSize(LanczosResize(a,Width(a)*1,height(a)*1),S afeAviW,safeAviH,rate)
a = trim(a,0,alength)
at = loop(at,25)
inpoint = d.framecount+a.framecount
martinique_avs_directshowsource.avs -
EDIT: I just tried this app on 250 images - It used 560MB. I'm assuming you have 512MB of total RAM in your machine? Fuggedaboutit....
I had this problem too with high resolution photos.
Before running my avs script, I just resize all my photos with a height of 600 pixels and all was fine, 500 is ok for ntsc
It seems that avisynth is converting a jpeg to bmp in memory so a 6 megapixles photo takes a lot of memory.
AVIsynth plugin development: memory leaks..[resolved 7/17/2011]
By vhelp in forum ProgrammingReplies: 17Last Post: 18th Jul 2011, 11:47 -
Sudden RipBot error (avisynth error)
By Charles314 in forum DVD RippingReplies: 5Last Post: 24th Oct 2010, 01:44 -
Memory mapping error
By Illusionist in forum ComputerReplies: 1Last Post: 12th Jul 2008, 22:15 -
Corrupt Memory Error
By denmc in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 8th May 2008, 08:24 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
