Sorry, but how else can I explain?
Hi all, unfortunatly, I have about 5 lengths of cable to send Composite from Satellite Scart to Capture card input. Does the above image show noise lines due to a poor cable, or is this something else? Cable length is not an issue, I've used a longer one that I borrowed and had to return. Also, the audio and video shield are connected together, had to do this to improve image.
Also, how can I shift that black strip down the right hand side of the image? I can crop it or resize it but prefer it gone before the signal gets captured.
I use Ulead Movie Factory 4 and Dr.DivX.
Cheers Mike![]()
a:bad cable
b: your card got a tv tuner and so you get interferences
my card has like you one single input for everything audio and video and so far i haven't had big problems
Sometimes i had lines(only noticeable on the preview) and this is interference with the tuner i believe but since i don't use the tuner i don't get them anymore..or very rarely*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Thanks themaster1,
I thinks its the cable. I don't use the tuner, just the Composite in. I thought I'd be okay, because the cable is screened. I'll buy a new cable.
Cheers Mike
Can you suggest a DVD Player ?
By Mohanraman in forum Software PlayingReplies: 1Last Post: 23rd Apr 2010, 14:36 -
Suggest brand sub forums
By pszilard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 27th Dec 2009, 21:06 -
May I suggest a new smiley?
By lordsmurf in forum FeedbackReplies: 5Last Post: 25th Jan 2009, 18:54 -
What author program would you suggest
By pupa in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 04:20 -
Please suggest which is better DVDShrink or DVDRebuilder?
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 22:00
