Hi,
I have a LG DVD burner and have a problem with one specific DVD. I have a set of four DVDs (DVDs contain a PBS program). Disks 2 - 4 load fine on my PC.
Disk 1 works fine on my standalone DVD player. However it does not even appear on My Computer after I insert it into my PC. Hence I cannot use NERO Showtime or Power DVD to watch it. When I press PLAY on my Power DVD it simply says "A disk with an unsupported format is in Disk G". I assume that is a default message (I get it even when no disk is in the drive).
When I insert the disk the access light flashes maybe five times over a few seconds and then stops.
Is there something on the disk that could prevent the disk from loading on the PC? I am not even sure where to start trouble shooting this.
thx.
	Hi,
 I tried this DVD on another PC and it worked there. So, the next question is if someone could explain that and/or give me some way of overcoming the issue since I only have access to the second PC occasionally.
 thanks.
  DVD works on DVD player but not recognised in laptopBy rline101 in forum DVD RippingReplies: 6Last Post: 11th Oct 2010, 17:09
  trying to fix a scratched dvd, works on pc but not player...By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 10:02
  Sound works on Pc but not on Dvd playerBy Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 08:22
  DVDRW works fine on PC, not on DVD PlayerBy Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54
  my dvd-lo that works on Mac, not in external playerBy oldblues in forum ffmpegX general discussionReplies: 8Last Post: 11th Jul 2007, 04:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
