Hi guys, I have a ton of home movies (mostly in .avi and mpeg/mpg for mat) and would like to put them all together on a DVD with menus so I can show the family when they are over. I here Ulead Moviefactory has really bad audio sync problems so I am kinda scared about that. I do want a very high quality program (money is not an issue whatsoever).
However, I am not an expert in this type of thing, so I do want a program that is user friendly for a beginner like myself. Any help or opinions is welcome.
Thanks in advance!!!
Best: Some filtering with avisynth. Convert with cce basic or hcenc. Author with DVD-lab pro. But it's not that user friendly...
I would test the latest tmpgenc dvd author 3, good encoder and authoring...but a bit slow though. -
If money is not an issue give Ulead DVD Workshop a try. Very easy to use and very flexible. Most operations can be accomplished via drag and drop. Tons of templates or a blank slate, whatever you want. If you already have some footage in MPEG format it's ideal because you just include them in a project as is. This is particularly true if they have multiple bitrates, resolutions etc.
As far as an y audio sync issues go with Ulead products I can't say I have experienced any. I know there has been some problems in the past with specific versions such as Video Studio 8 when MPEG was the source. Since fixed in the latest versions. -
Originally Posted by orbital517
What Program was used to create these menus?
By BIGD22 in forum Authoring (DVD)Replies: 14Last Post: 21st Nov 2011, 18:43 -
Best program to create a DVD (with menus) from MP4s?
By namrufmot in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2010, 21:18 -
How to create movies that is playable in home DVD players from a movie DVD
By vain in forum Video ConversionReplies: 2Last Post: 16th Mar 2009, 01:10 -
Trying to create a process for creating home movies reliably and need help
By Arphahat in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2009, 11:19 -
Looking for a simple program to redo dvd menus for my home movies
By brycej817 in forum Authoring (DVD)Replies: 2Last Post: 24th Jan 2008, 14:31
