Hi to all.
First of all, sorry for my english..
The question: I have some dvd captured with neoDVD (the only software that works with my usb device) with LPCM audio. It's a very large format and I'd like to convert it in ac3.
Well, it's a little bit frustrating, because I had just solved this problem last year, but I have fogotten how!
I used TmpgEnc plus with ac3 plugin, and I though "Hey, it's that simple?" ahhrgg..
What I have to do is just to take the vob, and change audio from lpcm to ac3.
Thank you for your help,
Davide
Don't cross post please.
Reopening this thread, as the one I decided to keep open has been deleted.
/Mats -
tmpgenc dvd author with the ac3 plugin, add dvd video or the vobs and select to convert to ac3 audio.
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Change bitrate of LPCM 5.1 ch ( audio file after demuxing )
By wisitch in forum AudioReplies: 3Last Post: 8th Apr 2010, 13:09 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 12:25 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 09:09
