My source file is .vob, it converts just fine into 1 large .DVfile, but despite all attempts and settings i've tried, i cannot get it into chunks. at all. it always comes out as 1 large file. I need smaller pieces so i can import the .DV files into iMOVIE. What is the proper procedure for chopping up .vob files into specific sizes?
What is the source of the vob file? How are you getting it, from a DVD HDD, a Handycam DVD, what? When I record onto DVD on my DVD recorder, I can specify VR mode or Video Mode. If you chose VR mode, it will be one large file, if you chose video mode it will be broken up into files no larger tha about 1.4gig. You could use editing software like Womble Video Wizard to break up the large file into smaller mpg files, then if you renamed the mpg exension to vob, that should work too. Mpg files and Vob files are interchangeable.
The source files are from a dvd, the original file was an imove file, that got corrupted, so now, i'm trying to get the file back into imove by converting the .vob files into .dv files. The source .vob files are fairly large, about 1.5 gigs each, but, when turned into dv files they are way past imovies 2 gig file size limit. If there is a way that ffmpegx can take a 1.5 gig .vob, and make several smaller chunks that would be ideal.
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 07:23 -
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 10:37 -
"Could not find any VOB unit in VOB file(s)" - Using Ifoedit
By devilcoelhodog in forum Authoring (DVD)Replies: 1Last Post: 1st Feb 2010, 23:01 -
Auto-split 10 hr capture in 3 min chunks "on the fly"
By atvmxr in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2008, 10:48 -
automatically cutting a large wav file into x minute chunks?
By graysky in forum AudioReplies: 5Last Post: 22nd Sep 2007, 23:12
