Real noob here trying to figure out why when I DL an xvid file that a Video TS folder isn't created.
I have learned that it is better to just burn an xvid file (providing stand-alone player is capable) rather than converting it to DVD format from a quality standpoint. I got that part of it, but I am confused on burning the file. I burned the file as a data disk in NERO. How do I create chapters and such? Would that be authoring? I have IMG burn(haven't figured it out yet).NERO which I really don't like and VSO's convertXtoDVD which I use, but don't need it to convert xvids because my stand alone is capable. I am assuming that DL xvid files won't automatically create an Video TS folder. IMG burn should be able to burn the file to the disk but I cant figure it out. Is there decent freeware that will enable me to author the file as well? Any help would be appreciated .
Thanks....Crowheart
The Video_ts folder is only for dvd-video and xvid files are not any dvd-video. If you want menus and don't want to convert you need a divx ultra certified dvd player and then author with a divx authoring tool like divx author, tmpgenc dvd author 3, divxmediabuilder.
edit: i'm not sure if it will work to put xvid files in those authoring tools though... -
ImgBurn can burn any kind of data to a disk. But if you want a Video DVD, you have to prepare that data first (using an authoring app, that mostly expects mpg file(s) as source, so if you start with an XviD, you have to encode that to mpg first of all).
If your player plays AVI DivX/Xvid you can burn your AVI with ImgBurn as it is.
Seems like you'd be using convertx2dvd for your AVI to DVD needs. It takes care of the whole process from almost any format to ready Video DVD.
And before anyone comes here to recommend WinAVI as a substitute for convertx2dvd - Don't listen. WinAVI is (and has always been) crap - possibly the worst commercial offering in software history.
/Mats -
I guess my problem is I can't figure out how to burn the xvid file in Imgburn(my stand-alone can play xvids-so I don't need to convert). I would ultimately like to get rid of NERO even as a NOOB I can see that it is problematic. I was hoping Img burn was a solution.
Thanks...Crowheart
WinFF 1.40 portable doesn't save folder options
By jgg in forum Video ConversionReplies: 2Last Post: 19th Jun 2012, 15:53 -
m2ts-file doesn't show video
By chrit in forum Blu-ray RippingReplies: 5Last Post: 19th Apr 2012, 11:28 -
Why doesn't handbrake re-encode show video bitrate in MediaInfo?
By KushSmoka420 in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 16:55 -
subtitle doesn't show in MPCHC
By alexanderex in forum SubtitleReplies: 2Last Post: 28th Feb 2011, 21:45 -
Video doesn't show while playing .mp4 files
By shiningwizard in forum Video ConversionReplies: 2Last Post: 17th Jul 2008, 02:16
